Sponsored by: Kumho
92 Explorer ABS light
Old Mar 4, 2004 | 08:34 PM
RobertGordon's Avatar
RobertGordon
Angry 92 Explorer ABS light
92 Explorer with rear ABS. Never really could tell from new if I had ABS (ie. no pulsing pedal etc). Dash ABS light is now on steady. Replaced rear axle ABS sensor to no avail.
What next?
Old Mar 4, 2004 | 09:32 PM
MustangGT221's Avatar
MustangGT221
Check codes
Old Mar 5, 2004 | 06:32 PM
sty's Avatar
sty
I had an `88 F150 , with rear ABS. When the light came on , Lucky i pulled the rear wheels ,and found a wheel cylinder leaking profusely , and shoes that were paper thin. Check the master cylinder to make sure it`s not low and that you don`t have the same problem I did.
Please post your result
Good luck
Sty
Old Mar 6, 2004 | 01:15 PM
walt88's Avatar
walt88
What was the result of your problem? I have a 92 E250 with a similar problem.
Thanks.................................WALT
Old Mar 6, 2004 | 07:19 PM
martys repair's Avatar
martys repair
I have a steady ABS light on - '94 E150 4WABS.. light came on the day after LesSchwab rebuilt my front brakes! - No evidence of damaged wires though, and I don't know where else to check! -- the code readout is 539, which tells me exactly nothing with my chiltons book.
HELP
Old Mar 6, 2004 | 08:22 PM
sty's Avatar
sty
Walt 88 , the result was the shoes were so worn that the wheel cylinder actually was leaking brake fluid and on the verge , say 1/16th of an inch more and it would have popped that wheel cylinder right out complete with the rest of the fluid.. The light came on to warn me of potential problem . So , I changed both wheel cylinders(given the year) and put fresh shoes on. Light went off right then.
I would physically inspect the the brakes and make sure you have some meat left on those shoes and pads, make sure no brake fluid leaks . Other than that , check sensor or pull the codes.
Good luck!
Sty
RadioControlGuy85
16
Oct 14, 2015 11:35 AM
njtinman2
Dec 8, 2014 05:05 AM
renchr56
Aug 10, 2014 04:47 PM
Rentaro
May 28, 2014 08:13 AM
Mikeman
Nov 10, 2013 12:34 PM
