Sponsored by: Auxito
Front End
Old Oct 23, 2006 | 03:31 PM
Fxxer's Avatar
Fxxer
Front End
This maybe nothing, but I just switched to BFG all terrain tires and I hope it is just the tires but when i apply the brakes or turn a corner the front seems to grind a little and I hope it is just the aggresive side wall and not the wheel bearings. I have 57,000 miles and never noticed this with the old tires. The brakes aren't grinding its just that the front end goes down or foward momentum cause a grinding sound in the front tires. Does anyone know when wheel bearings should be replaced?? Thanks again this forum always helps.
Old Oct 23, 2006 | 05:09 PM
steve(ill)'s Avatar
steve(ill)
well, its not the bearings because they would grind all the time. it has something to do with the brakes or front end nose dive condition. i would put on a jack and rotate the tire, then apply brake and see if something is touching or a rock in the discs, ect.
Old Oct 23, 2006 | 05:32 PM
slowride66's Avatar
slowride66
What are we talking about?{year make model}?
Wheel bearings will go for a long long time it maintained properly.
If you hear something grinding you need to be looking for tell tale signs .
If the brakes are going a visual inspection is needed
same with the bearings.
Did you change to different wheels?
Did you go with a bigger size tire?
SR66
Old Oct 24, 2006 | 08:51 AM
Fxxer's Avatar
Fxxer
Sorry guys 2003 Fx4 Supercrew and I kept the stock tire size I just went to the BFG allterrain. I believe it is just the aggressive side wall that when the tire compresses I am feeling the tread on the side wall through they steering wheel. I think that is what I am feeling, but did anyone ever have this issue with different tires? Also jacked up the front, no tierod play, no grinding when I spin the wheels and everything seems tight. Its got to be the tire noise.
jsniska
Nov 29, 2009 09:27 AM
Galveston Yankee
Offroad & 4x4
Feb 29, 2008 10:14 PM
mybigredford
17
Nov 12, 2007 05:18 PM
83scrambler
19
Nov 6, 2007 03:58 PM
Powerstrokedlariat
Jan 23, 2005 02:47 PM
