i picked up a power slider off of evil bay about a year ago... installed the glass in the truck this spring... and to my surprise their was already the right plug behind my super cab seat cushion.. so I plugged it in and chased the wires... the wires terminate in the toe kick..
I have to run wires from the plug in the toe kick up to the switch I bought from the ford dealer, cut a hole in the dash for the bigger switch pannel, and finish installing it..
just havent found the time.. but hey at least I can say I have a power rear slider..
Hi all, I converted my '01 250 from manual to power slider and I love it!! window assembly with motor, cable, wire harness, switch, window gasket, came in one box. all from Ford for about 600 bucks. had a service install the glass for a separate charge, now I dont have to turn around to open/close the slider. F81Z-25422B30-AC part # for power sliding rear window assembly
