rear sliding window question
Old Oct 4, 2015 | 09:09 AM
RadioControlGuy85's Avatar
RadioControlGuy85
guys got an rear sliding window out of the junkyard,
it came out of an 80s f150 i think it was an 85,question is will it fit into an 92 f150?
Old Oct 4, 2015 | 09:35 AM
silar's Avatar
silar
If I remember right, it should be pretty much the same between 1980-1996. I think that is the way LMC shows it.
Old Oct 4, 2015 | 09:39 AM
RadioControlGuy85
yea thats what iv came up with also, just wanted to get some feed back or if anyone here has done it. got the window for 30 bucks. i couldnt pass that up.
Old Oct 4, 2015 | 09:55 AM
FordPUMan's Avatar
FordPUMan
I've thought about doing that. Are you going to use a new seal or
the existing one?
Old Oct 4, 2015 | 10:16 AM
RadioControlGuy85
the existing one?
we are hopping to use the old one.
Old Oct 4, 2015 | 10:26 AM
Galendor's Avatar
Galendor
If the seal is not cracked, split, or torn and still reasonably flexible, you can. I did - I just cleaned it really well with soap and water (long bristle brush into the crevices), then let it soak in a heavy coat of armor-all. It was shiny and flexible again after that.
Old Oct 4, 2015 | 11:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Same: 1973-1996 F100/350, 1997 F250 H/D & F350.
Fixed it for you.
Old Oct 4, 2015 | 12:06 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If it is a factory slider you need the slider rear gasket.
The groove will fit over the wider channel of a factory slider.
If its aftermarket (like CRL) you can use the existing single glass gasket, because these are made with a flange the thickness of the old glass.
Old Oct 4, 2015 | 12:09 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
FYI, Go-Jo hand cleaner or 'personal lubricant' makes it a LOT easier to pull the rubber seal through the cab opening with a cord.
Old Oct 4, 2015 | 12:59 PM
RadioControlGuy85
just looked at the window and to me it looks like cheation with a logo of a C
Old Oct 4, 2015 | 01:28 PM
NumberDummy
If the sliding back glass latch is a cheap piece of plastic that has to be folded over upon itself, it's probably genuine Ford.
Old Oct 4, 2015 | 01:39 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
C. R. Laurence makes the DVL2 replacement latch in metal.
It's only about $7.
Old Oct 4, 2015 | 02:09 PM
RadioControlGuy85
ill get a picture of it.
Old Oct 4, 2015 | 02:26 PM
RadioControlGuy85
here it is.
it has a metal lock and plastic handles on each of the sliders
Old Oct 4, 2015 | 03:19 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
KY Jelly, petroleum jelly, or mineral oil are WAY Better than ArmorCrap. I've also used olive oil on weatherstrips,etc...Slather the seal and lay it in the sun for an hour or so......pliable. IMO....Armorall is garbage.
