1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2007 King Ranch power sliding window. One cable broken, can I replace?
Old 04-05-2015, 07:06 AM
stv1991's Avatar
stv1991
stv1991 is offline
I recently bought a 2007 F250 KR and the power sliding window didn't work. I removed the rear seat and rear decorative panel yesterday to investigate. The motor is working, I can manually slide this window open & closed. The cable on the passenger side is broken. Can I just replace the cable? Do I have to replace the entire motor assembly with both cables? Or is the whole rear window unit considered one piece?
Thanks in advance!
Old 04-05-2015, 09:37 AM
kengarchow's Avatar
kengarchow
kengarchow is offline
broken SRW cable
in my 06 had similar issue
wasn't able to buy just cable
whole rear cable section came as a unit, cast wasn't bad and install took about an hour
Old 04-05-2015, 10:12 AM
stv1991's Avatar
stv1991
stv1991 is offline
Did you have to remove the entire rear window assembly to make the repair? Does the sliding window pop out somehow? My cable is broken so I assume that a piece of the cable is stuck inside the window attachment point? I want to repair it, just want to know what I am in for.
Old 04-05-2015, 11:28 AM
ligito's Avatar
ligito
ligito is offline
Steel cable, or electrical cable/wire?
Old 04-05-2015, 08:41 PM
stv1991's Avatar
stv1991
stv1991 is offline
Mechanical cable that moves the window. There are two. Right & Left.
mattn03
09-30-2018 08:16 PM
MBBFord
2004 - 2008 F150
12-27-2013 05:48 PM
oldhokie
Escape & Escape Hybrid
07-27-2012 12:33 AM
Hank85713
2004 - 2008 F150
08-06-2009 09:35 PM
Quick Reply: 2007 King Ranch power sliding window. One cable broken, can I replace?
