help: 4x4 low doesnt work
Old Oct 18, 2006 | 07:54 PM
pimpedrsrage's Avatar
pimpedrsrage
i have an 02 f350 diesel and i have shift on the fly, but it doesnt engage into 4w low for some reason. it engages into 4w high just fine but doesnt get into low. im not a genius when it comes to mechanical stuff but any ideas on what it could be? i guess its not that big of an issue since i'd rather have 4 high than 4 low, but would be nice to know what might be the problem. thank you-
Old Oct 18, 2006 | 07:59 PM
MAKO314's Avatar
MAKO314
straighten up the front wheels put the truck in neutral wait a few seconds then try the 4 low, sometimes if the driveline is in a bind it won't engage right away. it does the front end good to go into 4wd ocationaly it keeps everything lubed up
Old Oct 18, 2006 | 09:13 PM
kawika's Avatar
kawika
Don't you have to stop the vehicle and press on the brake to get it to 4xLow?
Old Oct 18, 2006 | 09:51 PM
axetil01's Avatar
axetil01
Shifting into 4x4 low
Shifting into neutral, then rotating the switch from 4H to 4L should let you enter into 4L. I have a '99 F-350 and this is in the owners manual.
Old Oct 18, 2006 | 10:13 PM
kbeefy's Avatar
kbeefy
Yup, neutral or park and foot on the brake.
Old Oct 18, 2006 | 11:31 PM
Pocket's Avatar
Pocket
Nope, only neutral AND foot on the brake will engage and disengage 4Low. It's in the owners manual. Other combinations don't work.
Old Oct 19, 2006 | 07:22 AM
Uzumati's Avatar
Uzumati
Put tranny in neutral and see if it will crank.... Could be Trans gear position sensor
Check brake lights... Could be a Brake Pedal Applied switch
Old Oct 23, 2006 | 12:16 PM
pimpedrsrage
i engage the 4 low by putting into neutral with foot on brake, and keep front wheels straight and it usually locks in but i've tried the last couple of times and it hasnt work. thanks for all the replies i think i will end up bringin it into the dealer
Brian Donoghue
15
Jan 10, 2014 10:58 AM
jonc123
Oct 23, 2013 03:58 PM
beckman
2004 - 2008 F150
Jan 2, 2013 07:25 PM
ebraunusa
Dec 16, 2005 09:02 AM
ebraunusa
Feb 3, 2005 08:26 PM
