Help w/ 4x4 light blinking
Old Oct 22, 2013 | 03:00 PM
jonc123's Avatar
jonc123
Hey I have a 2002 explorer. The 4wd does not seem to be working properly. it will not engage in 4 high but will engage in 4 low. also the 4 high light blinks about 10 times when i press the 4 high button. Does anyone know what this could be from. I have read some similar stuff but not exactly the same. not sure if i am looking at the motor that engages the 4x4 or the module. any help would be appreciated.
Old Oct 22, 2013 | 03:10 PM
merlynr's Avatar
merlynr
Disconnect the module clean the pins and reconnect.
Old Oct 22, 2013 | 05:39 PM
jonc123's Avatar
jonc123
Thanks,
Ok I did that and also disconnected the connector that connects the 4 wheel motor on the case and still nothing.
Old Oct 22, 2013 | 06:56 PM
jonc123's Avatar
jonc123
OK so It turned out to be the ground wire that goes to the motor on the transfer case. I read that these get corroded, but in my case it just broke from the point of ground. Ran a new ground wire and everything works. Thanks for reading...
Old Oct 23, 2013 | 03:58 PM
merlynr's Avatar
merlynr
Glad you had an easy fix. Thanks for update.
Jeff Meyer
Jan 1, 2018 09:50 AM
Force4000
Jul 9, 2014 08:41 AM
awsmev
16
Jan 15, 2010 07:34 AM
midnightride_42
1997 - 2003 F150
Sep 25, 2008 10:23 AM
Dwarwick
Offroad & 4x4
Jul 21, 2002 01:02 AM
