1997 4X4 Engagement Problems
More than likely the linkage is froze up. This happened to me a few years ago. Pull the the shifter boot from inside the cab and you will have better access to the linkage. 2 large bolts, can't remember the size, I also had to cut and peel the trans tunnel a bit to access them better, but it will come out. Get it on the bench, hose it real good and start working it loose. Once apart grease the crap out of it. I have a link to more instructions from when I had my problem, but it's on the PC. Let us know if you still need help and I'll dig them up tonight.
on
I believe so. I am pretty sure the metal bar that goes from the shift lever to the linkage on the transfer case is different length. But the length difference is quite a bit I believe. But if you used all the auto stuff shouldn't be a problem. The metal bar is the only difference. When I broke my lever the used one I got had a bar on it so I just swapped everything on but it wouldn't match up with the shift notches, would always have to go by feel. After I found out that there are different length bars, I put the original bar onto the replacement shifter and it worked like it is supposed to. But I think the length of the bar is different for different transmission / transfer case combos.
Hi, I have a 1997 Ford f250hd 4x4 and my shift linkage would not get out of 4wd. I tried a bunch of different things but wouldnt move. Unfortunately i guess i put too much pressure on it and something broke underneath. I believe it is a bracket that holds the shift linkage and moves it from 4wd to 2wd.Can you please help i'm at a loss considering i'm not very good with automotive work. Thanks Rich
if you have any ability and a anyone who can TIG weld aluminum
https://www.ford-trucks.com/forums/1...er-repair.html
If not. (NOT sure of the quality)
you'll have to get underneath to see what broke in linkage. if you're lucky the connector bar just popped off one of the two studs its pretty onto. if so, just pop it back on. if its something else, you'll have to post some pictures...
and for future reference, if your truck is an automatic, I found it easiest to shift in to 4x4 if I dropped the truck in to Neutral. that, or do it when coasting in gear. mine was always tough to get into 4x4 with the truck in park or in gear not moving. ...since I've converted to manual it works well all the time, though :-)
