Sponsored by: Real Truck
brakes grabbing
Old Oct 10, 2006 | 02:11 PM
jlowid's Avatar
jlowid
brakes grabbing
Hey guys.this is my first time on and need some help.I have a 2004 super duty,4x4 5.4 the brakes started to grab and there was a ringing sound.I put new pads in the front and now they are grabbbing more. also the metal dragging sound is still there. could this be a front wheel bearing?will a bad wheel bearing cause the front to studder when braking?any help is appreciated.thanks-joe
Old Oct 10, 2006 | 02:30 PM
SteveVFX4's Avatar
SteveVFX4
if it shudders when you brake, then most likely your rotors are warped. I would try new rotors first.
Old Oct 10, 2006 | 05:27 PM
jlowid's Avatar
jlowid
thanks steve. it doesn't studder while braking when moving on the road only the last few seconds when coming to a stop.I know I usually have the weird problems nothing straight forward. joe
Old Oct 10, 2006 | 07:20 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Joe, WELCOME to FTE!
That "ringing" sound, I guess it's not the typical brake squeal/squeek?
If you jack up the front of the truck, grab each front wheel and rock it back and forth, up and down, left-to-right, does it move at all?
Old Oct 10, 2006 | 09:20 PM
RACERX7775's Avatar
RACERX7775
my excursion does the same thing. i have pics in my gallery of my brakes. they are the powerslot and hawk pads. 13000 miles.it sounds like the typical metal to metal grinding sound when the brakes are down to the rotors. there is tons of material left on the pads but the sound is horrible. i think that its the aggressive pads that caused this.
Old Oct 10, 2006 | 09:27 PM
ReAX's Avatar
ReAX
WD40 will stop most noises and keep the pads from grabbing. Unfortunately, it will also make stopping very difficult.
One thing to try, for high end sports cars a product is available that is like rubber cement, that you apply to the back of the pads. It keeps the pad back plate in contact with the caliper piston and usually reduces brake squeel on hi-po applications. Performance friction once offered it, but I am sure some one out there still has it.
Old Oct 11, 2006 | 06:37 AM
jlowid's Avatar
jlowid
thanks guys.I'm going to jack it up this afternoon and check for wheel movement-joe
Old Oct 11, 2006 | 09:45 AM
krewat's Avatar
krewat
That stuff isn't just for "hi-po applications".
I've used it for years.
I forget it's brand name, but Permatex makes one, and so do others. I've found it in blue and red.
RACERX7775, that doesn't sound good. If you hear anything grinding when you apply the brakes, get it fixed. Something is wrong.
Unless you're talking about crawling very slowly with your foot on the brake, then you SHOULD hear some shuddering, but never metal-to-metal grinding.
Old Oct 11, 2006 | 01:03 PM
RACERX7775's Avatar
RACERX7775
i agree, and while truck stops perfectly, the sound makes it sound like a pos. i think i am going to get rid of the lousy powerslots and get the performance friction stuff. oh, and the metal to metal sound is when i am slowing to a stop. i have beed a ase master mechanic for over 13 years now and i am sure that its the pad to rotor noise.
Old Oct 11, 2006 | 03:24 PM
jlowid's Avatar
jlowid
tHANKS TO EVERYONE.
GOT THE ROTORS TURNED AND IT SEEMS TO HAVE FIXED THE PROBLEM.THIS IS A GREAT FORUM--JOE
hurst1979olds
15
Feb 21, 2017 02:14 PM
Shattered
Nov 19, 2015 09:08 PM
TurtleTruckSC
Sep 4, 2014 03:19 PM
U-HIGH75
Aug 19, 2012 06:25 PM
shad44
1983 - 2012 Ranger & B-Series
22
Jun 16, 2012 07:23 AM
