Grinding and squeezing when applying brakes
Old Nov 19, 2015 | 11:57 AM
Shattered's Avatar
Shattered
Drivers side front squeals when slowing down and right before trucks stops it really grinds and grabs. Replaced brakes but that wasn't it. Could it be a bad hub or wheel bearing? I know someone has a pretty good idea as to where I should start.
Old Nov 19, 2015 | 03:15 PM
Rikster-7700's Avatar
Rikster-7700
Did you check and grease your slide pins and check the calipers for sticking when you did your brakes?
Old Nov 19, 2015 | 05:55 PM
Zwalters's Avatar
Zwalters
When you say you replaced your brakes, did you check both sides of the rotor? If that was all good, jack up your truck and rotate your tires (fronts I'm assuming) with a sharp ear. You'll know when it you hear it.
Old Nov 19, 2015 | 09:08 PM
Shattered's Avatar
Shattered
checked it, figured it out, it is the hub and bearing assembly. not a bad fix couple hundred bucks and she'll be good as new.
Bdlm06
1997 - 2003 F150
Dec 4, 2015 06:56 PM
teamlx88
Jul 26, 2010 04:25 PM
mizzitch
Aug 7, 2008 03:04 PM
carpe_diem
Oct 20, 2004 05:39 PM
