DFPE sensor location....?
Old Sep 29, 2006 | 09:09 AM
Randolph's Avatar
Randolph
hey all, I had the local ford dealer ship do a diagnostics on my truck and they said I need a DFPE sensor. Can t find any referance to it in my manual. I had it in the shop for some re-call work. What and where is this sensor? 1995 F-250 4x4 with a 5.8. thanks all.
Old Sep 29, 2006 | 05:03 PM
Rockledge's Avatar
Rockledge
It'll be bolted to the upper intake manifold. Has one electrical connector and two hoses coming off of it. Looks like THIS.
Old Oct 2, 2006 | 04:29 AM
Randolph's Avatar
Randolph
thanks for the reply, I looked all over my truck and in my Haynes manual and still cannot locate the sensor.
Old Oct 2, 2006 | 07:09 AM
EPNCSU2006's Avatar
EPNCSU2006
If there is an EGR valve position sensor on top of the EGR valve, there won't be a DPFE sensor. You can pull diagnostic codes yourself on that '95, just search google for "EEC-IV self test." Sometimes the same code can mean different things for different vehicles, but I'm not sure why the dealer would not know the correct meaning for your truck.
Old Oct 2, 2006 | 08:41 AM
projectSHO89's Avatar
projectSHO89
Eric is correct. The 95 5.8 has the EVP located on the EGR valve. No DPFE sensor involved.
www.fordfuelinjection.com has a good procedure on pulling your OBD-I codes.
Steve
Old Oct 2, 2006 | 03:39 PM
Randolph's Avatar
Randolph
thanks all for replying, I called the dealership and they didn't elaborate on it but said the part was 142.00 bucks. I called the local parts shop and they said the position sensor was 35 and change and the pressure sensor was 62 and change. Should I get them both? Not sure which , but I ain't rollin in extra cash so.....what do you think? thanks again all
Old Oct 2, 2006 | 05:52 PM
EPNCSU2006's Avatar
EPNCSU2006
If you don't see the pressure sensor mounted to the front of the intake manifold, and you see a position sensor on top of the EGR valve, don't waste time buying a pressure sensor. It should be obvious if you have one or not.
Old Oct 3, 2006 | 03:49 PM
Randolph's Avatar
Randolph
ok thanks, the position sensor it is. I'll pick one up tomorrow . thanks again
hondamxr
Oct 10, 2016 08:26 AM
hondamxr
Oct 9, 2016 07:30 AM
andykwells
1997 - 2003 F150
Jun 8, 2015 01:08 PM
Adriandude8544
May 30, 2014 12:11 PM
ranger9496
User Gallery & Picture Display
Jun 11, 2002 05:16 PM
