Alternator question
Old Sep 29, 2006 | 09:35 PM
ReAX's Avatar
ReAX
Alternator question
On a 3g/6g alt, there is a harness of three wires and a charge wire. Looking over my manuals, There is a jumper wire, if they were in the same harness, it should have been done internally. So I believe there is a connection from the charge wire back to harness. Is that right?
Old Sep 29, 2006 | 09:40 PM
Franklin2's Avatar
Franklin2
Here is the schematic. What is your question? The jumper wire is actually a wire, and it's white with a black stripe.
Old Sep 29, 2006 | 09:52 PM
ReAX's Avatar
ReAX
Does it loop at the harness or does it follow the harness back a little ways and splice into the charge wire?
Old Sep 29, 2006 | 09:54 PM
Franklin2's Avatar
Franklin2
It does not splice into the charge wire. It's just a loop. It connects the stator windings to the internal regulator.
Old Sep 30, 2006 | 11:36 AM
ReAX's Avatar
ReAX
Well I pulled the alt loose again. Two wires run into the pigtail and one is bolted to back of the alt. Two alternators so far, one old and one new. Neither produce a charge at the batt, pos batt and alt case, alt case and alt bolt. I did notice my volt meter fluctuate .03 volts up when I reved the motor. So either one of the wires is cut/disconnected or my truck has a gift for blowing regulators. What do the outer most pins on the harness do? My harness is different from the 90, so I imagine that blk/org and yel/wht are the charge wires. one goes to the cluster, so does the other connect back to the battery?
Old Sep 30, 2006 | 11:50 AM
ReAX's Avatar
ReAX
I turned the key on, walked around to the alt and tapped the back of it with a file for 10 seconds. I never felt a magnetic pull, so Which wire provides 12v for the field coil?
Old Sep 30, 2006 | 12:40 PM
ReAX's Avatar
ReAX
Both wires in the harness have battery voltage and very low ohms. The alt ground is ok. is there a way to test the alt without a bench tester.
Plus both charge wires have a good connection.
Old Sep 30, 2006 | 02:36 PM
ReAX's Avatar
ReAX
After a lot of research and seeing very diagram show a cluster light, I have decided this is a new symptom of my cluster, KSM issues. I guess I am going to the dealership next week.
Old Sep 30, 2006 | 07:46 PM
Franklin2's Avatar
Franklin2
Does the above diagram match your wiring?
1. You should have your large wire for the output of the alt(I think you are calling this the charge wire). It's the black orange wires.
2. You should have the yellow/white wire. This is the feedback wire. It sends the system voltage back into the regulator, so the regulator knows how much to tell the alt to charge.
3. You should have the green/red wire. This wire should have voltage on it when you turn the key to run. This brings the alternator "online" so it will charge, and takes it "offline" so it will not run the battery down whe the engine is not running.
4. You should have the white/black jumper.
Old Sep 30, 2006 | 07:58 PM
ReAX's Avatar
ReAX
No. Mine is a 6g. I have a large yellow (and red 1/0) charge wire that is bolted to a stud on the back of the case. The voltage regulator has two wires, one blu/org and one org/ylw I think. All of which tie back to the battery with the ign off. No jumper and the fusible links are inches from the battery and turn into a red wire.
Old Sep 30, 2006 | 10:37 PM
ReAX's Avatar
ReAX
Any clue on how to activate the regulator? I haven't tested yet if the connections change with the key on, but what I have seen so far is the cluster light has to draw on the regulator.
Old Oct 1, 2006 | 01:04 PM
ReAX's Avatar
ReAX
org/blu is closest to the charge stud and is connected to the battery. Grn/Red is the field wire and furthest from the the stud.
This afternoon, not touching it for 24hrs. The Grn/Red wire had .03volts and org/blu had battery voltage. KoEo both wires had voltage, but the grn/red was less than the org/blu meaning it has draw with the key on. This tells me the truck is fine. I'm charging the battery back up (10.3 volts currently) and I'll check it out again in a little while.
Old Oct 1, 2006 | 01:29 PM
ReAX's Avatar
ReAX
Old Oct 1, 2006 | 02:24 PM
ReAX's Avatar
ReAX
Still no charge. Still no battery light.
Old Oct 1, 2006 | 05:02 PM
Franklin2's Avatar
Franklin2
We started out on the wrong foot here. I was basing all responses to your questions on the above diagram, which I believe is a 3g diagram.
Let's start over.
You have a 2002 f250 correct? And you are retro-fitting a 6g alternator on it? Do you know what vehicle the 6g came standard on?
