the map sensor should work fine thats where i have mine tapped into and it reads correctly. my guess is there is a leak somewhere or you have it int he wrong line ill try to get a pic tomorrow for you where mine is
Here is the link to the installation instructions from Diesel Manor (www.dieselmanor.com). The install instructions include photos for all 3 guages. Also note that the Boost bulb can be bigger than the pyro & tranny bulbs, they show a picture using a black permanent marker to dim the bulb down a bit. Worked for me.
Once you check and have verified that you tapped the correct boost line try checking the brass fitting that you used to install the boost guage line to the T-fitting. Sometimes it's easy to overtighten that brass piece and crimp it shut.
Hope this info helps
Yeah Pete, you don't have to tap into the AIH area. The map sensor hose t-fitting works fine too. I was just curious how you were checking that boost tube as like I said, mine are a pushlock and I wouldn't want to try to pull the tube out for fear of boogering something up.
Pete,
The link that white Buffalo sent is exactly where I mounted my tee fitting. I would like to find a compression fitting like the one pictured because I have blown my slip on rubber boot off the barbed tee twice now. Makes me nervous when I once had boost then no boost at all.
Pete,
i just put a very small hose clamp on each side of the barbed tee to make sure the hoses didnt blow off
thats the set i got from dieselsite, and i just verified my hookup and it has to be 100% correct,,,i have the same compresion fittings , so i know its fine,
thanks a milion to all of you guys, you have been a lot of help, ill kep you posted once ill get new boost gauge and sender for pyro,
i hope that will correct the problem
Peter
hey guys ,
a little update on my gauges,
i got the replacement gauges from Bob at Dieselsite, and its all good,
the pyro was Bad, and so the boost gauge, so im back up and running, and my temps now shoe around 300after a minute idle, which is now more normal
thanks a lot for all the help,you guys a very suportive
thanks
and best regards to all of you
