Help with gauge install
Old Sep 5, 2004 | 04:59 PM
mejer1's Avatar
mejer1
I am in the process of installing my gauges this weekend. I have autometer gauges, pyro, boost, and trans temp. I am installing on my 2004 F-350 CC SB 6.0L
The questions I have is on hooking up the boost gauge and trans gauge. On the boost gauge I remeber reading that a good spot to hook into is just left of the turbo. I think I have found the hose is it the one that runs from where it hooks up on the cowl into the passenger side valve cover?
On the trans gauge would a good spot be the line that is pumping fliud to the cooler? If so which line the front or rear on trans? Its the 5 speed torq shift.
Thanks for all the help
John
Old Sep 5, 2004 | 05:37 PM
tsheriff's Avatar
tsheriff
Boost line you have located correctly. And yes you want to hook the trans temp before the factory cooler to know your max temp. But i got a 6 speed and cant tell you which line it is.
Mike Hannahs
30
Sep 19, 2013 12:05 PM
wldcat65
Jan 31, 2010 09:19 PM
Billyclub
May 12, 2009 03:31 PM
06PSD&79460
Nov 9, 2006 07:45 AM
Gage2502
Modular V10 (6.8l)
Feb 25, 2006 11:42 AM
