another oil leak
Old Sep 27, 2006 | 01:59 PM
turkeyman's Avatar
turkeyman
Angry another oil leak
I have read all the threads on oil leaks but still can not locate mine-- Cleaned the engine and still know luck- Oil collects in the front of the intake just below the fuel filter and then to the back and down. it doesn't leak at idle which makes it harder to locate. I have tightened everything I could find- Does any one have pics of were to look
Old Sep 27, 2006 | 02:03 PM
OfficerDangle's Avatar
OfficerDangle
sounds like the high pressure oil pump (hpop)
Old Sep 27, 2006 | 02:34 PM
turkeyman's Avatar
turkeyman
Ok but how do you get it off- does it have O-rings or replace it
Old Sep 27, 2006 | 02:57 PM
Kwikkordead's Avatar
Kwikkordead
I think there is a special tool that you need to use, similar to the ones that you use to separate the AC lines.
