Riding Lawn Mower
I'm helping a friend find a riding lawn mower for there house. I guess between the front and back yard its about an acre or so. Just a little too much to push mow. Also a riding tractor comes in handy for the snow blowing and the utility cart hauling.
I've been doing most of the research and have learned quite a bit but still not sure what band or model to go with. Looking for a ride on with bagger at not much over $2500. $2500 is mak but still trying to keep it under $2000. Need the tractor to last a good 10+ years be fairly reliable and be able to get parts for it 10 years down the road. THey have a 88(I think) model 18HP Craftsman now. Looking to stay away from Craftsman for now.
I've determined that a pressurized motor has about double the torque of a splash(non pressurized) system. So most likely I am looking for pressurixed oil system motor.
Looking on input on the differant brands out there. John Deer (X300 but it's a little over budget), Toro, Airens, Honda, Huskavarna, any others??? Troy Built is out as well as models from Lowes & Home Depot. I heard Troy Built is hard to get parts for after models change.
https://www.ford-trucks.com/forums/3...ing-mower.html
https://www.ford-trucks.com/forums/4...rn-mowers.html
https://www.ford-trucks.com/forums/4...asshopper.html
https://www.ford-trucks.com/forums/4...r-acreage.html
https://www.ford-trucks.com/forums/2...wn-mowers.html
https://www.ford-trucks.com/forums/2...awnmowers.html
https://www.ford-trucks.com/forums/1...a-pick-up.html
Every time I look at the new ones they seem to have more plastic, more safety switches, and more other crap I don't want. Just my opinion...
It's like anything else, if something is going to break...it will, regardless of who made it.
I'm not going to say anything bad about the power equipment D'pot sells, but if it's good enough for them to sell, it won't show up around my place.
My Dad had a 1963 110 that worked until he sold it (it was a collector's item by then).
Million 2 of the links were real usefull the others were just rambelings...
I think I'm staying away from the JD 100 series as they don't have a pressurized system. I may end up with the tractor in a few years and I will also be the one to mainly use it. The friend I'm talking about is my close to 65YO mom. She can't use the Craftsman she has now (mower deck leaver is a PITA to use and takes lots of strength to lift. The front wheel bearings are starting to go, the ignition key switch is basicly busted and needs fenessing to turn it and the one and only time I think it was services was back around 91 or 92)
Right now I am leaning toward Toro or JD. The Toro salesman told me to get a small 17hp(Kohler) one with manual PTO because he was having/seing troubles with the larger ones with electric PTO and B&S motors(deaseling and not starting correctly).
A JB sales man turned me off on the 100 series and towards the X300 (I don't need the AWS of the X305). The X300 is pushing it money wise so it might be out as well.
I looked at Airens and Honda but they only make the "no front crumple zone" type ride on's. Are they good for towing and such or just strictly a mower with a seat?
And as for Lowes and HD. I saw a JD 195 there and did not see a 195 on the JD web site, just up to 155.... Hmmmmm... Special retail model?????
I also looked into Ingersall and they are way over budget and limited dealers. I did a quick look into the MTD line (Troy Bilt, Cub Cadet, etc) and want somthing a bit beafier. And Husky.... They were out of the loop before I started as well as few others I can't think aobut right now.
It seems that your purposes are not real well aligned with your mom's, though- tractors designed to be easy to operate (e.g. easy lifting decks, light steering) probably won't be too good for the harder work you'd like to do with it.
If you're looking new, I'd be inclined to buy on dealer as much as on brand- seems like many of the people I've talked to who've bought new tractors in the last few years have had issues with them, and a good dealer who will work with you on whatever warranty the machine has would be a real good ally. (My uncle bought a Scotts at Depot and a drive-belt pulley shattered within minutes of use. HD wouldn't give him a new pulley, he had to buy it (for $7, but still...).)
