Trailer Paint?
Old Sep 6, 2006 | 06:15 AM
killerklown's Avatar
killerklown
Trailer Paint?
Picked up this little IH steel yard trailer last weekend
http://i115.photobucket.com/albums/n...7/MVC-820S.jpg
Anyone have any tips for cleaning, priming, and painting it. It's going to be a spray can job, since I don't have a sprayer.
Old Sep 6, 2006 | 08:19 AM
jake00's Avatar
jake00
Actually, I'd brush on rustoleum
Old Sep 6, 2006 | 08:22 AM
lswartz's Avatar
lswartz
It looks as bad as my basement steps entry cover. I used navel jelly & rust-oleum (used one of those paint brush sponges) 2 days ago. I just checked it after yesterday’s rain & there are little spots or rust showing up again. I haven't even had a chance to put on the 2d coat of paint. While it looked good, I must have missed something.
Old Sep 6, 2006 | 01:03 PM
surewhynot's Avatar
surewhynot
I would sand down the rust as much as possible then prime and paint using rustoleum. I did this 2 years ago on my flatbed, using the spray can primer and the brush on paint. It still looks good today.
Old Sep 6, 2006 | 01:43 PM
Mil1ion's Avatar
Mil1ion
You know there are ton of great ideas in the "appearance" forum.
I was surprised how many different products there were out there to use.
For years I always used Tremclad.
Old Sep 6, 2006 | 08:51 PM
jake00's Avatar
jake00
thats the Can version of Rustoleum
Old Sep 6, 2006 | 10:29 PM
furball69's Avatar
furball69
I painted a couple of our 16" trailers this spring. Pulled them to the sandblasters and blasted everything, wood sides and all. I highly recommend a brush and roller instead of the spray can and I used tremclad.
Old Sep 7, 2006 | 07:32 AM
killerklown
Yes, I sure wish I had access to a blaster. I guess elbow grease will have to do...Thanks guys, I never would have thought about brushing it on.
Old Sep 7, 2006 | 10:47 AM
furball69's Avatar
furball69
Problem with the spray cans is; when/if you're down to bare metal, it's hard to get enough paint on to actually prevent it from rusting. I used two coats of primer and at least three coats of paint and some of the paint is rusting through but where I rolled it on the metal, there is no rust. and it looks better than where it is sprayed. If you put it on thick enough, the brush strokes/ roller marks level themselves out and it looks great... I ised the brush to cut in where the roller wouldn't go then roll the rest.
Old Sep 8, 2006 | 07:55 AM
rebocardo's Avatar
rebocardo
What I do for almost anything painted "cheap" is sand and prime multiple coats and then brush on Rustoleum. I usually use Hunter Green if doing anything Ford. Problem with Rustoleum is it shows scratches. I bet a gallon of bedliner would do the whole thing and then some.
nut1605
Jun 22, 2010 07:48 AM
dixiemudder04
Feb 9, 2008 07:19 AM
kermit
Jan 2, 2007 12:48 AM
nick11082001
Jul 19, 2003 11:12 AM
BShows
15
Dec 18, 2001 05:14 PM
