Has anyone got a Bad Boy mower that is what it is called if so do you like it
it sure looks heavy duty or what you have and how it is holding up as far as
a zero turn mowers will be cutting grass before you know it
Never haeard of it. Who makes it or is that the companies name? If it looks well built and the price is right whats the availability of parts. Does the dealer stock most? Can you get them overnighted if they don't stock it?
I've had a bunch, Bunton, Gravely, Scags, Exmark, and there's a whole lot more out there. Had the best luck with the Exmarks. The dealer I use stocks just about a whole machine in parts. If they don't have it it'll be there the next day.
Ive worked for several Lawn Services and I have used the 61" Scag Turf Tiger and a Exmark Lazer Z.
The Scag is not a bad mower for the money but the Exmark was the best ive used. Those mowers will supprise you when you get on the throttle they can fly on a yard.
There has been a lot of talk about Bad Boy mowers over the last few years among commercial guys, but have yet to run across one in use or even talked with anyone who owns one. I find that a bit unusual. The dealer I bought my Hustler from carries the line, so it's not like they are not represented in the area. Looking at it, there doesn't seem to be anything inherently wrong with it. Maybe the marketing is just not quite right.
I have three BobCat mowers. Two walk behinds and one rider. There great mowers, had one of the walk behinds for 5 years and have had no problems but rutine maintence.
Cub Cadet makes a line of ZTR mowers, both comercal and consumer. I have used their comercial M60 & M72 mowers. They are mowing machines. Last i heard the M72 is going to come out with a diesel motor option. The one i used had a 28hp gas. With the deck under the mower you can get tighter turns around objects than with the deck out front.
