blinking headlights
Old Dec 9, 2001 | 06:11 PM
grantchaffee's Avatar
grantchaffee
blinking headlights
Please help I have a 64 F250 4x4 that after the headlight or an for about 15 min. or so the start blinking like turn signals. It does not make a diference if in high or low beam, I reblaced the dimer switch and that didnt work. Any suggestions at all would help thanks guys....
Old Dec 9, 2001 | 08:22 PM
Franklin2's Avatar
Franklin2
blinking headlights
There is a circuit breaker in the headlamp switch. One-either it's working correctly, and you have a bare wire shorting to ground, you've added fog lamps or something to make it trip, or two-it's getting weak and you need a new headlamp switch.
Old Dec 9, 2001 | 08:23 PM
airharley's Avatar
airharley
blinking headlights
Sounds like you have a liitle corrosion in the connection under the dash. Or you could have a wire crossed with the turn signals. Does it happen as you are driving down the road or just when it standing still? Look at the head light switch from under the dash. You will see a white wire with a red strip that should be your head light wire. Chances are is that i\the wire has become corroded under the insulation and connector.
Old Dec 9, 2001 | 08:50 PM
jjb's Avatar
jjb
blinking headlights
mrvwbug
Jul 29, 2016 08:08 PM
chiefsfootball
Jan 8, 2015 03:13 PM
1970RedF100
17
Dec 31, 2014 05:32 PM
88PONY
Dec 13, 2013 09:23 PM
kasparsport
Electrical Systems/Wiring
Oct 30, 2002 11:11 PM
