HELP WITH HEADLIGHTS OR ALL LIGHTS
Old Dec 10, 2013 | 09:52 PM
88PONY's Avatar
88PONY
Question HELP WITH HEADLIGHTS OR ALL LIGHTS
OK HERE WE GO 1996 F150 220,000 on it the headlights and only the headlights come on when I pull the switch all the way. Parking lamps won't work at all. If I move the switch in between where the headlights should go off and the parking lamps should be on everything works. I replaced the headlight switch and that's not the problem. Turned my hazards on and my left rear wasn't blinking but my 4x4 light was and the truck is 4x2....oh and I put new bulbs in the rear lights just to be sure. I think there is a bad ground somewhere??? anybody have this problem?
Old Dec 10, 2013 | 11:35 PM
Red454sedgwick's Avatar
Red454sedgwick
Your on the right track with the ground, the one from the firewall to the block can cause all sorts of trouble
Old Dec 11, 2013 | 09:11 AM
88PONY's Avatar
88PONY
might try running one from the battery to the frame. had a similar problem on an 83 ranger and that worked
Old Dec 11, 2013 | 07:59 PM
88PONY's Avatar
88PONY
Cool
ok, im lost is it possible the turn signal switch is no good? sometimes with the hazards on the 4x4 light blinks
Old Dec 11, 2013 | 08:02 PM
eakermeld's Avatar
eakermeld
No, that's got to be a ground problem. The blinky stuff is circuit feedback.
Old Dec 11, 2013 | 08:11 PM
88PONY's Avatar
88PONY
well i put a cable from the battery to the frame and no luck...where shoud i try next ya think??? thanks for helping
Old Dec 11, 2013 | 08:20 PM
eakermeld's Avatar
eakermeld
Go from the battery to the cab next. After that, find the ground next to the fuse box and run a good wire from the battery to it. After that, I'm not sure. Others here will be glad to help also.
Old Dec 11, 2013 | 08:56 PM
danr1's Avatar
danr1
Did you look at the plug for the headlight switch?
They get hot melt and deform causing problems with lighting.
I'd look at that that and if find no problem there I next thing I might suspect be the multifunction switch.
Old Dec 11, 2013 | 10:47 PM
88PONY's Avatar
88PONY
Smile
plug at headlight switch is fine. looks like factory nothing melted. ill try the battery to cab and check the fuse box ground tomorrow thanks for the help
Old Dec 12, 2013 | 11:17 AM
dixie460's Avatar
dixie460
Truck's telling you she wants a 4x4 conversion.
Seriously though, I can see this being a case of one or more circuits having lost a ground, so now they are grounding thru whatever else is available such as lamp filaments.
I wish I had detailed schematics on hand like some other members... then I could take a better look. Think it's time for me to get a Ford manual...
Old Dec 13, 2013 | 09:23 PM
88PONY's Avatar
88PONY
Question
Ok, tested all grounds and everything is good. Sometimes as I said the left (driver side) brake light won't work so i'll put the left blinker on and boom it works....i've heard the turn signal switch does fail, and the ones I see in the parts stores are for auto trans only, mines a stick think it will work?
apbtpetey
Electrical Systems/Wiring
Dec 1, 2008 02:18 PM
1957F100
Jul 25, 2007 03:48 AM
joshdell7743
1997 - 2003 F150
Sep 23, 2006 07:09 AM
mike2002
1983 - 2012 Ranger & B-Series
Dec 27, 2005 06:51 PM
STiNGeRX
Jun 8, 2001 10:06 PM
