5.0 Engine Dying
Old Aug 30, 2006 | 02:11 PM
bandit990's Avatar
bandit990
5.0 Engine Dying
Today when i started up my truck the RPM's were lagging behind the gas pedal. it was a one second or so lag and i figured i could make it back to my house. as i drove, i began to feel a thump as if i had something attached to my tire the engine slowly lost power until it stalled and i wound up on the side of the road. I have a 1990 Ford F-150 with 4wd. I think it may have something to do with either the transmission or the fuel lines but thats about all i know. this is my daily driver so i really need to figure out what wrong in a hurry.. any help would be greatly appreciated.
Old Aug 30, 2006 | 03:21 PM
Kemicalburns's Avatar
Kemicalburns
pull codes, even if there is no check engine light something will get stored. to do so check otu www.fordfuelinjection.com for instructions how. its easy and will take 5mins. check your fuel pressure at the rail, might replace fuel filter if its been awhile. did it run out of gas maybe? do you hear the fuel pump kick on?
Old Sep 1, 2006 | 03:51 PM
bandit990's Avatar
bandit990
I havent pulled the codes but i have found out that when i shift into a different gear it doesnt happen, it also stops lurching when i take my foot off the gas. does that help home in on what it could be?
skyoung
Aug 15, 2009 08:28 AM
Mydiesel250
May 13, 2008 04:37 PM
LAWNMOWER MAN
Jun 28, 2006 06:52 PM
ktplotts
Jul 19, 2005 12:08 PM
johndeerefarmer
Jun 7, 2005 03:38 AM
