86 F150 C6?
Old Aug 20, 2006 | 06:54 PM
ericsmith32's Avatar
ericsmith32
86 F150 C6?
My dad has a 86 F150 with the 5.0L/auto. I'm assuming the automatic is a C6? What type of fluid does this tranny take? I've always assumed Type F until I read through some posts on here saying Mercon instead. The family has had this truck since 94 and we've never changed it, only put 40-50k on it though. The fluid is still a reddish color though. The problem it's having is similar to slipping when trying to pull something heavy, the transmission maybe shot. The plan is to drop the pan change the filter and replace whatever is lost. I don't know if the c6 has a drain plug but if it does I will change it every couple months till it looks good.
Old Aug 20, 2006 | 07:38 PM
stuart1's Avatar
stuart1
It could have either a C6 or AOD.
The dip stick will say what fluid to use.
The pans do not have drain plugs, (the pan will have to be removed), but the convertors do.
Old Aug 20, 2006 | 11:17 PM
bradb2230's Avatar
bradb2230
And dont over tighten the pan bolts when you put it back together.
bull jr
Sep 30, 2014 08:27 PM
BigBlockF350
Sep 16, 2013 06:21 PM
mjb86
Mar 25, 2013 10:04 PM
omni
Feb 4, 2005 09:26 AM
dj8667
Jun 20, 2004 01:14 AM
