explorer trans problems
Old Aug 20, 2006 | 07:04 PM
dmc919's Avatar
dmc919
I recently helped my friend put a junkyard automatic transmission into his 91 4x4 4.0 explorer cause the one that was in it burnt up after hauling his ranger. Well the transmission will only shift into reverse no forward gears, the back tires are off the ground and nothing happens in the forward gears. theres no delay with reverse either. I think it's a simple problem cause everything has to lock up in the tranny in order for reverse to work except for the foward drum, right?
Old Aug 20, 2006 | 07:40 PM
stuart1's Avatar
stuart1
Either the forward clutch or the o/r clutch are toast.
Get out the jam and peanut butter.
Old Aug 20, 2006 | 07:42 PM
dmc919's Avatar
dmc919
dang stuart you got a funny saying for everything hehe, anyone else got an idea that would be simpler like a sensor is bad or something
Old Aug 20, 2006 | 07:48 PM
stuart1's Avatar
stuart1
A sensor will stop a shift from one gear to another from occuring.
It first needs a clutch to be engaged.
Old Aug 20, 2006 | 11:44 PM
bradb2230's Avatar
bradb2230
Stuart hasent led me astray, so I would belive what he said. He told me what was wrong with mine before I got the thing tore down to find out. Yup you were right Stuart, is there any way that the manuel shift linkage isnt hooked up right thought? I dont know dmc, but he is the guy to ask.
Thanks Stuart for all your help with my transmission. I am getting photos together and as soon as I figure out how, I would like you to look at some of the parts to see if anything else my be damaged, besides the clutches of course.
highfly24
15
Aug 1, 2021 11:01 AM
mflowers1794
2004 - 2008 F150
Aug 28, 2016 05:02 PM
Onamisn
Jan 13, 2016 08:43 PM
Benjamin Morrison
Modular V8 (4.6L, 5.4L)
Dec 30, 2015 11:33 AM
JakeOHara
Dec 19, 2006 01:10 PM
