Oil Bypass Filteration System?????
Old Aug 21, 2006 | 08:33 PM
  #31
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Originally Posted by LVEILLON
I'd like to see their setup...I went to the site, but it's the same nightmare of navigation that I remember before.
Beach...Can you provide a partial link. The part number for the bypass doesn't show up on their site.
No link and not yet on their site... can send you an email with a PDF file attached.
Old Aug 21, 2006 | 08:42 PM
  #32
Kep4's Avatar
Kep4
Jäger
www.oilguard.com/ford_bypass.php
Old Aug 21, 2006 | 08:52 PM
  #33
Beachbumcook
Got Diesel?
Originally Posted by Kepler4
I think he meant the Racor site for by-pass filters?
Not on there yet... I only have the PDF file they sent me via email.
  #34
LVEILLON's Avatar
LVEILLON
Originally Posted by Tim Lamkin
I told you it worked three years ago!
Now Tim...You know you can't just say "It Works" and expect people to believe that especially when you know Jeff needs some real science
I know the filtration works while the base pressure is fufilled, but my biggest concern is that this system was not engineered into the oil pressure requirments of the engine. Since I change my oil at all the intervals recommended by Ford @ Ford it just seems like an added expense to keep my oil extra clean for them to change out at the regular intervals required by Ford.
As I've said I am not knocking the system, but haven't seen any actual installs showing how or where it's located. I'm all in if there's proof of safe oil pressure at any rpm. I'm also interested in the logic behind it from oil bypass owners.
Since I change my oil at all the intervals recommended by Ford @ Ford it just seems like an added expense to keep my oil extra clean for them to change out at the regular interval.
Thanks
Old Aug 21, 2006 | 09:01 PM
  #35
Beachbumcook
Got Diesel?
However, the guy I spoke with, Dave, commented that the reason that my oil analysis's are the same or vice versa with someone with by-pass filtration is that the stock 20 micron filter is doing a great job and the truck with the by-pass set-up is not being worked that hard.
He claimed that using it is fine, but for trucks in dirty, dusty "severe use" is where owners see an advantage using by-pass filtration. He finished by saying that for the moderate to minimal towing I do and the highway miles that I drive (oil heats up and stays hot), that this is why my oil analysis tests are coming back good.
He also commented on the "shearing effect" of the oil by the 6.0L motor and agreed that by-pass filters only filter out soot and insoluables.. but running a "sheared oil" too long is not good either... so he agreed that 5,000 mile intervals are a good idea regardless of oil.
I will now support oil by-pass systems, but have chosen not to spend the money for one since I change my oil and filter every 5,000 miles and based upon my driving habits it is not warrented due to oil analysis results not reflecting enough of an improvement... and do not want the hassle of any warrenty problems as I do not have the time to fight it (right or wrong on Ford's part... I am not wasting my time to fight it if it should happen).
Old Aug 21, 2006 | 09:36 PM
  #36
mrxlh's Avatar
mrxlh
Must be an echo in here, maybe not three years ago, but I also stated that they do indeed work.
Ryan
Old Aug 21, 2006 | 09:46 PM
  #37
Kep4's Avatar
Kep4
Jäger
The Racor part # is LFS RK860F. Maybe try these:
www.maesco.com/products/racor/r_lfs_intro/r_lfs_intro.html
www.dieselpage.com/raclfs.htm
Oilguard is a sponsor and their system looks good. Here's more reading from the past: www.ford-trucks.com/forums/284098-new-oilguard-aluminum-billet-kits.html
Old Aug 22, 2006 | 06:12 AM
  #38
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I know Jeff so well, it does not matter what you give him, he will… to his credit, do an exhaustive research and leave no stone unturned (in this case no drop of oil left un-examined) to get…. where he wants to go.
Does not matter what any of us say….
Old Aug 22, 2006 | 11:11 AM
  #39
Beachbumcook
Got Diesel?
Thank you I guess... I think that was sort of a compliment... maybe?
Old Aug 22, 2006 | 03:23 PM
  #40
Odge's Avatar
Odge
Has anyone ever used a centrifugal filter similar to what over the road truckers use.
Old Sep 4, 2006 | 11:23 AM
  #41
dapgar's Avatar
dapgar
i'm new to these type of bypass systems, doesn't look like a hard install. question though, does it work with the current oil filter, or is the stock on removed and just the one ont he frame rail is doing the work? when it says bypass, it seems like it wouldn't use the current one.
i'd like to get one of these setups on my new truck, and possibly for my 97psd.
i do change the oil every 3k miles,, are these bypasses changed at the same intervals or longer?
while my truck has no miles on it, it would be nice to have one of these systems from the beginning.
thanks
Dan
Old Sep 4, 2006 | 12:25 PM
  #42
IB Tim's Avatar
IB Tim
YUP...sure is
Old Sep 5, 2006 | 01:48 PM
  #43
fast_st's Avatar
fast_st
Just one note, no science data yet,
I recently installed the oilguard kit on my 1999 7.3 psd. I found that the install kit, cost about $25 included 12+ feet of parker push-loc hose and fittings as well as all of the needed hardware. The install took about 20 minutes once I found the bracket fit almost perfectly on the backside bolts that hold the fuel pump on the frame rail on the drivers side. I was highly impressed that they included a piece of 5/16 bar stock to help remove the plug for the return line. That one little thing seems to show a great attention to detail. The filter mount appears to be milled from a piece of 2" billet plate and then hard anodized.
I have sent in 2 oil samples so far at 10k miles, the results look great so far and the $200 cost for the kit plus spare bypass and fuel filters has been reclaimed in skipping 2 full oil changes at narry $100 each w/rotella-t snyth. I'm looking at maybe 20k between oil changes. Seat of the pants data, at 10k the oil is transparent gray, looks about the same as 10 minute old oil normally.
-Jason
DavenTn
Dec 6, 2016 10:58 AM
tractordaryl
Jan 11, 2013 05:37 PM
HOME WORKS
Sep 17, 2006 07:21 PM
bkvanbek
Nov 20, 2004 11:40 AM
fsnco1
Modular V10 (6.8l)
Jan 20, 2003 01:27 AM
