Should I get an....
Old Nov 19, 2004 | 06:22 PM
bkvanbek's Avatar
bkvanbek
Should I get an....
...oil bypass filter? I was about to order Oilguard oem air, oil and fuel filters and I saw these oil bypass filters. What do ya'll think of um?
Old Nov 19, 2004 | 07:11 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
The OilGuard system is the best.....no others compare and their prices on OEM oil filters are unmatched anywhere...IMO...buy
Old Nov 19, 2004 | 08:14 PM
bkvanbek's Avatar
bkvanbek
Tim and others with an opinion
Your not bias are you, since they are a supporter? I am going to buy from them the other filters. But I need a good reason to buy the bypass system and I am trying.
Anyone else have an opinion?
How long should you go between changes with the bypass system. I change every 3,000 now and use Rotella T.
Old Nov 19, 2004 | 08:22 PM
Daryl Hunter's Avatar
Daryl Hunter
A friend of mine used to be in that business and he said that the Oilguard was very a good product.
How long you go between oil changes should be dictated by how your oil analysis reports look. Start at the factory recommended change interval and then start working your way out longer.
From what I've read on this board, the limiting factor for the 6.0 might be viscosity breakdown by the motor beating the oil to a pulp. Again, oil analysis will show this.
Old Nov 20, 2004 | 05:39 AM
IB Tim's Avatar
IB Tim
YES, I am biased; I bought my OilGuard and installed it long before they ever became a sponsor.
I did not report on this forum until months after the installation and use… if it was good or not. Did this all on my own, without the knowledge of Ken the owner of FTE and Mark the owner of OilGuard….I am JUST like you a consumer…I will standup for any product that first, is technologically sound and second, the company will stand behind their product, and third they are decent to work with….(This is my personal requirements for any company) OilGuard exceeds in all of these categories and FTE is proud to have them as a sponsor. Remember without sponsors you and I are not on this site learning ……I also support MotorHaven and ALL of the sponsors of FTE
Old Nov 20, 2004 | 08:36 AM
bkvanbek's Avatar
bkvanbek
tim, how long do you go between oil changes? I can not see myself having my used oil tested.
Old Nov 20, 2004 | 11:40 AM
IB Tim's Avatar
IB Tim
You do not test the used oil, (so to speak) you stick the cup under the OilGuard unit and run a bit of the current oil in the cup, and send it off...then, when the analysis comes back you say time to change or wait another 2k and repeat the process...some go 2k more some 3k more some check every 3k or 1.5k…all up to you
Liquid10Rider
Mar 30, 2012 10:45 PM
spadasak
Oil & Lubrication
Apr 8, 2008 01:10 PM
firemediceric
27
Mar 24, 2007 02:10 AM
HOME WORKS
Sep 17, 2006 07:21 PM
numocystic_10
Oil & Lubrication
Sep 7, 2002 11:28 AM
