Knobs 63 F100
Old May 14, 2002 | 06:35 PM
chickenmanq's Avatar
chickenmanq
***** 63 F100
Does anyone know how to remove the plastic ***** such as on windshield wiper switch? I'm guessing there's a tool, but have resorted to bolts cutters and wired a new temporary switch until I order one from LMC.
Old May 14, 2002 | 08:13 PM
banjopicker66's Avatar
banjopicker66
***** 63 F100
[updated:LAST EDITED ON 14-May-02 AT 09:14 PM (EST)]Hey, there's a little trick! This applies to the dash control *****, not the radio or headlight. Each **** is held in by a spring friction clip. Under each **** is a little indent. Insert a pointed object, like a nail, and slide it into the indent. This will push the spring clip in, towards the front of the ****, and allow you to pull the **** off. (Keep pushing on the indent until it comes off, though.)
Headlight switches are different. Now this what I'm about to tell you is good back to at least '64, according to my knowledge, but it may be different for '63 and earlier; I just don't know about the earlier ones. I doubt it has changed, though. Anyway, the **** is permanently attached to the shaft. You must remove the **** and shaft together by pressing on a spring loaded button or detent on the switch. This detent is just inside the dash. That is, it is located close to where the switch mounts to the body. It is located on the top of the switch, where the bottom of the switch is the connection for the wiring harness. You will probably find it much easier to remove the instrument panel to see it.
Hope this helps!
Old May 15, 2002 | 07:38 AM
William's Avatar
William
***** 63 F100
Chickenmanq! Geeze "bolt cutters", When I get that pissed I go for another brewski. John gives good advice! I would add hammer the nail flat and file it smooth to make a narrow flat blade. Slip this tool/blade along the top of the switch shaft, into the indentation of the **** and gently slide the **** off. Try this on the one you removed with bolt cutters and see how it comes off. Others un screw and like John said the headlight **** is special. I saw in the junk yard where someone had taken an axe to the dash of a 72 to get the heater out.... Chickenmanq, you don't own an axe do you?
William in Atlanta
Old May 16, 2002 | 11:25 PM
chickenmanq
***** 63 F100
>William in Atlanta
Well, no, no axe, but I do own a machete, a framing hammer, and a blowtorch. Usually I don't resort to such madness, but I had already determined the switch was bad, and since I was replacing it with a temporary switch anyway, out came the bolt cutters. Actually, it's more a lock cutter. Cheap version but has removed many locks. Sucks I gotta replace the headlight switch and ignition. Oh well. They're kinda expensive. And why the hell did Ford put the fuse box into the headlight switch? What kind of retarted reasoning is that? I'm done venting. Have to go study for Com 400 final. Summer session blows.
Old May 17, 2002 | 01:16 AM
jonathan219's Avatar
jonathan219
***** 63 F100
Old Aug 6, 2022 | 12:53 PM
Engine-Ear's Avatar
Engine-Ear
Lightbulb
I will be sharing my success with this on my '66...
Old Aug 6, 2022 | 09:43 PM
stephen.osborne1's Avatar
stephen.osborne1
Holy zombie thread Batman!
Old Aug 6, 2022 | 09:46 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
A tumbleweed just blew past here and got stuck in the cobwebs. Twenty years.
Old Aug 7, 2022 | 06:08 PM
Engine-Ear's Avatar
Engine-Ear
Thumbs up
For sure!!
...UNLIKE Zuckerboy's F-book, FORUMS have staying power and a post a guy makes doesn't get lost like movie credits.
More to come on my results...
ERG4Life
15
Mar 17, 2024 11:25 AM
Shadowrider123
Sep 8, 2014 04:56 PM
powerstrokedieselfan
Oct 11, 2010 09:11 PM
334eagle
May 21, 2010 08:35 AM
tmwindham
1978 - 1996 Big Bronco
Oct 24, 2004 12:10 AM
