how to remove wiper switch knob?
Old Jun 2, 2013 | 01:59 PM
ERG4Life's Avatar
ERG4Life
how to remove wiper switch ****?
Hey Guys,
I am wondering how to you remove the **** to the wiper switch? I see a grove in the ****, is there an allen key or something? Thanks.
Old Jun 2, 2013 | 02:18 PM
march's Avatar
march
Theres a little metal tab on the inside that is angled so that it will slide on but grabs in the off direction. You need to get something in there to push on the tab while pulling on the ****. I use a a hooked scribe or probe. Line up with the notch in the ****. You'll still need to pull on it pretty hard.
Old Jun 2, 2013 | 02:37 PM
montana_highboy's Avatar
montana_highboy
Before you ask....
headlight switch **** removal...
Old Jun 2, 2013 | 03:00 PM
ERG4Life's Avatar
ERG4Life
Thanks Guys! Just to be clear on the wiper switch I need to put a probe in where the cut out is? Is that correct?
Old Jun 2, 2013 | 03:04 PM
JWC 3's Avatar
JWC 3
Yes . And release the holder tab .
Old Jun 2, 2013 | 03:14 PM
ERG4Life's Avatar
ERG4Life
I bent a T-pin but I just can't seem to get it to release. Is that to small?
Old Jun 2, 2013 | 03:25 PM
JWC 3's Avatar
JWC 3
You have to pull back towards the **** to release , while pulling **** . Don't pull to hard
Old Jun 2, 2013 | 07:21 PM
march's Avatar
march
Maybe this will help. You have to depress the tab and pull the **** at the same time.
Old Jun 8, 2013 | 03:52 PM
ERG4Life's Avatar
ERG4Life
Just wanted to let you know that I got the **** of wit ha little help from my local Ford dealer:-) I just didn't have the right tool. All is good now as I have working wipers. Now onto the U-joints and leaky exhaust.
Old Mar 28, 2022 | 05:48 PM
Peter41's Avatar
Peter41
Might be a dead thread, but this is super helpful. That retaining "clip" inside the wiper ****, is it supposed to be glued to the inside of the ****? My **** just pulls off but the clip stays on the wiper stem. I have taken it off with needlenose, but as soon as I put my **** back on it just spins.
Old Nov 30, 2022 | 07:41 PM
Raygunn1's Avatar
Raygunn1
I would like to know the same thing. My old **** is in good shape but the clip just slides out. I have bought a few different ***** that all fit but do not look correct.
Would I be able to take the clip out of a new **** and maybe glue it to the old ****. I don't wanna spend 30$ on one but I like the correct look.
thanks
Old Nov 30, 2022 | 07:54 PM
Peter41's Avatar
Peter41
thanks
Most likely. Mine was just old and eventually rounded itself off to the point the **** would just spin. Should just be able to swap out that metal sleeve and have no issues!
Old Nov 30, 2022 | 08:05 PM
John89's Avatar
John89
LMC has them for about 9.00 and Bronco Graveyard for about 11.00. I think Bronco Graveyard has free shipping.
They both typically have pretty high shipping, so get some other stuff if you need it.
Old Nov 30, 2022 | 11:11 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Either 2 part epoxy the clip in the old **** (let it dry then install it on the switch shaft) or get a repop **** and clip.
Old Mar 17, 2024 | 07:20 AM
seawheels79's Avatar
seawheels79
2nd Gear
Thank you for the explanation and photo, exactly what I was looking for (1986 F-250)
