V code, B code upgrade finished
Old May 3, 2012 | 12:12 PM
  #61
Stewart_H's Avatar
Stewart_H
Originally Posted by kconrad
Guys, I have been reading alot on here about the spring upgrades. I am trying to find someplace that sells them or maybe get them used at a junk yard near the Indianapolis IN area.
Check with Steve at Tousely Ford parts. They are a supporting vendor hear at FTE.
Do the V-Codes need to be off of a F250 Superduty or just a standard F250?
"Standard" F250???
Are the B-Codes also off of a F250?
They are found on 250/350's, yes.
I think I can do this mod myself. I lowered my S-10 a few years ago and installed new rear leaf springs to get it down in the dirt!!! I know the Excursion will be more work but I think I can accomplish it.
Yep, you should have no trouble.
Here's a little "helper" post. https://www.ford-trucks.com/forums/1...l#post11373753
Stewart
Old May 3, 2012 | 12:27 PM
  #62
kconrad's Avatar
kconrad
I found a Pull-A-Part place here in Indy and they show having F250 and F250 Superduty's on there lot. What is the difference?
Thanks for the other info.
Old May 3, 2012 | 12:29 PM
  #63
Stewart_H's Avatar
Stewart_H
I dunno. Maybe the F250's without the SuperDuty designation are the older F250's.
Just a guess.
Stewart
Old Jun 6, 2012 | 11:28 AM
  #64
f150crewcab's Avatar
f150crewcab
Is anyone replacing tie rod ends, steering stabilizer or other related components while in the "mood?" I'm just gauging what other mods/upgrades, if any, are being done at the same time as the spring swaps.)
I just ordered my Rancho 9000 shocks (see $500 rebate offer Rancho Suspension: RANCHO® SHOCK & AWE PROMOTION) and am now looking for V/B springs.
Old Jul 21, 2012 | 07:05 PM
  #65
HeckLure's Avatar
HeckLure
Ex spring swap.
New to site and have looked at all options for a spring swap.
Ok I have a 2004 Ex with 6.0.
Looking to swap also, only looking for safer Truck, DO NOT WANT IT LIFTED TO SKYor BAHA look
If I put the new 2C3Z-5310-HA springs up front, 07 SRW 1-ton springs on the rear w/stock Ex 2 in block, 30mm sway bar and Bilstiens listed in beginning of this thread?
I own all this already just waiting to see if it will work.
Will it ride high in front or rear?
Thanks, Heck Lure
Old Jul 22, 2012 | 09:12 AM
  #66
the ponz's Avatar
the ponz
my results
HeckLure,
I performed the following, and ended up with these results:
_________________________________________________
V and X are replacements for the front springs
V code rated for 5200#
X code rated for 6000# (used on trucks with a snow plow package)
B code used for replacing the rear springs. I could not find the weight rating.
I installed the X's up front and gained around 3" of lift
I installed modified B's in the rear and gained around 4" of lift. The B code spring pack is modified by adding the two shortest leaves from the original Excursion spring pack to the B code pack.
__________________________________________________ ________
I, like you, had no desire to lift the truck, however, if you replace the stock front springs that have a negative arch, with the either the V or X spring pack, the body of the truck will rise 2 to 3 inches. And the same thing will happen if the rear springs are upgraded. A higher riding truck is unavoidable if you follow the recommendations in this thread.
Good luck
Old Jul 22, 2012 | 12:50 PM
  #67
Stewart_H's Avatar
Stewart_H
6,830lbs for B's.
Stewart
Old Jul 22, 2012 | 03:42 PM
  #68
C50bart's Avatar
C50bart
Thanks, Heck Lure
Heck take a look at before & after of the mods in this thread. 4" blocks and 3" hanger/shackle kit. I needed a visual to get a better idea when I was considering the swap.
http://photobucket.com/c50bart
Old Oct 8, 2012 | 11:03 PM
  #69
EXv10's Avatar
EXv10
Thanks, Heck Lure
Any stiffer springs you use will raise it.
v and b codes are the mildest.
Old Mar 11, 2015 | 02:46 PM
  #70
saltflatsracing's Avatar
saltflatsracing
Will this swap affect the right height of my lifted 2005 EX 4x4?
My truck has a Fabtech 3.5 lift
Or will i have to go back to the original front spring shakles?
Old Mar 11, 2015 | 05:33 PM
  #71
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
Holy three-year-old thread resurrection...
You probably won't get anything out of it, how does your Fabtech gain the lift? Does it use any of the stock springs?
Old Mar 11, 2015 | 06:44 PM
  #72
Drunken_Unicorn's Avatar
Drunken_Unicorn
Seems that your search tutorial is working!
Old Mar 11, 2015 | 06:47 PM
  #73
Krazee Matt
Veteran: Navy
What, that lil old thing? Lol. Thanks bud, since somebody locked it before I could say so in there.
Old Mar 11, 2015 | 06:48 PM
  #74
Drunken_Unicorn
They locked it?! THOSE MONSTERS!
Old Mar 11, 2015 | 06:54 PM
  #75
Krazee Matt
Veteran: Navy
Reason I was asking was because of that last part that I put in bold. If you still have stock springs and you just got lift from shackles and hangars, then you'll get more lift out of your rig with a V/B swap. The way you worded that last part has me curious, 3.5" lift is a LOT of shackle lift...
