Starting problem
Old Jul 23, 2002 | 06:15 PM
rayray2k22002's Avatar
rayray2k22002
Starting problem
Question: I been working on getting my carb and timing set, in the midst of getting it together... I thought I drained my battery but it's either my starter or my solenoid.
My lights come on full power when i try to jump it, it makes no difference... when i tapp the solenoid a little the starter will turn but slow(drag for a second) then nothing,,, it starts to smoke slightly....
The starter has been rebuilt and probably has been driven maybe 5 miles...
What should I do?
Old Jul 23, 2002 | 06:58 PM
banjopicker66's Avatar
banjopicker66
Starting problem
[updated:LAST EDITED ON 23-Jul-02 AT 07:59 PM (EST)]Rebuilt doesn't always mean anything. It sounds like you have a bad starter. I am assuming you mean the starter is smoking.
Other than that, check the following:
1. Your battery cables from the solenoid to the starter and from the solenoid to the battery.
2. That the starter is properly mounted, and not in there ****-eyed.
I think its a bad starter. Smoking means it is getting current, but it is burning up inside.
One other possiblity is the motor locked up? Try turning it by hand just to see; the parts store will be more convinced its the starter if you make that check.
Hope you find its an easy answer!
Let us know, OK?
PS: if the solenoid is smoking, change it out.
Old Jul 24, 2002 | 10:51 AM
William's Avatar
William
Starting problem
Ray, Replace the starter solenoid, solenoid to starter cable, Battery cable and battery to engine ground cable. You can buy all this stuff for a few dollars, represent good value for the investment and installation is a breeze. New cables and solenoid are a low cost way to eliminate a pile of headaches later on. I replace batteries at the three year mark and use the biggest battery that will fit in the holder. Then install a (Known good) battery. Try to start. If the starter is smoking, take it back to the Guy that rebuilt it and have him check it out. Have you got Pertronix yet? Flat cap, fat wires and platinum plugs?
William in Atlanta
Old Jul 25, 2002 | 12:34 AM
rayray2k22002
Starting problem
William,
I will replace the Solenoid again,,,its fairly new but only a few bucks,,,I have repaced all cables and it has a brand spankin battery.
I don't have the petronix yet but, real soon. I have performance wires on it.
I'll let you know hwat happens when i replace the solenoid.
Thanks
Old Jul 25, 2002 | 12:36 AM
rayray2k22002
Starting problem
The plugs that are in there are autolite no.46...
which platinum plugs should i use.?
Old Jul 25, 2002 | 04:18 AM
jowilker's Avatar
jowilker
Starting problem
Ray, Try another starter first. I usually us a reman with lifetime warranty. Rebuilts are not worth the time, and I can't remember when I changed a solenoid. I think I would skip the platinums too. I have sussessfully used Autolite 45 for a while, save that money for gas.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Jul 30, 2002 | 05:26 AM
rayray2k22002
Starting problem
I took the starter back to the guy that rebuit it, he forgot to do something,,,,once he corrected it, it started right up....
Still can get my timing and carb set correctly... I will probably take it to my mechanic and have him set those items for me.
Thanks for all your help.
Old Jul 30, 2002 | 08:46 AM
sgreen's Avatar
sgreen
Starting problem
Rich1953ard
Apr 28, 2013 10:34 AM
Tyler Rowe
13
Mar 8, 2013 04:35 AM
Brother Les
15
Jan 23, 2013 10:08 AM
51PanelMan
29
Oct 20, 2005 09:42 PM
Turbored
Sep 28, 2004 02:19 PM
