Which bolts to replace rusted ones?
Old Aug 4, 2006 | 08:23 PM
Bdox's Avatar
Bdox
Grade eight is probably overkill for fenders.
I use a spark test to get an idea of what kind of bolt I am replacing. That is to take the bolt to be replaced and touch it on a coarse grinding wheel. Watch the sparks as they come off the wheel. A soft steel spark will divide into two or three particles. (An example would be a screw from almost any product from China.) A very hard steel will divide into many points. If you want to see an example, touch a file, or a high quality wrench to the wheel and you will see the spark will divide into eight or nine points.
Wear goggles!
In any case, a harder bolt can always replace a softer bolt, it's just a matter of cost.
Old Aug 5, 2006 | 10:44 AM
AXracer's Avatar
AXracer
I am using button head allen SS bolts wherever they show for their clean look. I bought a box of 100 (don't get sticker shock!) 1" long 5/16" diameter along with a box of nuts, plain and lock washers. I have gone thru most of the bolts and will soon buy another box. I was able to score a bag of > 500 nuts and lock washers on ebay very inexpensively so I won't run out of those any time soon. Cheap SS fasteners will be attracted to a magnet, avoid those.
The kits are expensive since you are paying for polishing, and the problem is you don't get any extras for any other places you might want to use them. My Ace hardware store carries a good selection of SS when I only need a few of a special size. Most of the bolts on our trucks are 5/16" fine thread, but I couldn't find buttonheads in fine thread so I am using course thread, and hex head in fine thread where the nuts are captured.
Old Aug 5, 2006 | 02:42 PM
fking1's Avatar
fking1
Originally Posted by babyfacejack
Should I use grade 8 on the fenders, etc? Or is there something different? Thanks
Grade 8 is not needed on the fenders as there are no big forces involved . Having said that, I used the 8's on just about every fastener on the truck.
Made me feel good, LOL.
Fred
Old Aug 6, 2006 | 10:15 PM
CharlieLed's Avatar
CharlieLed
Grade 8 is a waste of money on non-load bearing bolts...ala fenders. As was stated previously, grade 8 in the suspension and motor mounts makes sense because they carry a higher load.
Old Aug 6, 2006 | 10:21 PM
Bdox's Avatar
Bdox
Of course if you use an impact on every bolt in your truck...
Old Aug 6, 2006 | 10:27 PM
WillyB's Avatar
WillyB
Face it, factory bolts have lasted more than 50 years - and the ones that did turn to rust did so because of user neglect. None of us will let mud build up in pockets, most of us will not drive on salted roads or, if we must, will rinse the salt off as soon as we get home.
Any bolt that meets or exceeds factory specs is good enough for me!
MRStace84
Jan 6, 2011 03:12 PM
choochoof150
Dec 23, 2007 02:33 AM
lowtrkn2k
17
Nov 7, 2006 01:24 AM
Micginish
Aug 8, 2005 10:55 AM
Longneck
16
Apr 8, 2004 10:21 AM
