Keyless Keypad Code
Old Apr 10, 2009 | 09:32 PM
  #421
arhuranna's Avatar
arhuranna
Hello,
I would like a copy of the codes. Thanks in advance.
Mitch
Old Apr 19, 2009 | 11:14 PM
  #422
lynsta's Avatar
lynsta
We can't find it on our '02 Excursion Limited. Has anyone found it on this rig? Lynsta
Old Apr 24, 2009 | 07:44 AM
  #423
SARGE/AF's Avatar
SARGE/AF
You know I have not seen anyone mention in here that Ford also says to look in 2 other places, It says this same thing in my owners manual.
1) on the computer box under the hood
2) Right/Passenger side of vehicle behind kick plate where the fuel cutoff switch is
Sarge
Old Apr 24, 2009 | 09:48 PM
  #424
lynsta's Avatar
lynsta
Thank you. We do not have a book. We will look in those places.
Old Apr 25, 2009 | 07:34 AM
  #425
vettdvr's Avatar
vettdvr
Note this does not apply to a 2000
Old Apr 25, 2009 | 09:42 AM
  #426
lynsta's Avatar
lynsta
What does not apply ? I have a 2002. Lynsta
Old Apr 27, 2009 | 05:49 AM
  #427
SARGE/AF's Avatar
SARGE/AF
I have been really busy between PGR and a family member that lost most everything they own to a fire for the last few weeks, but I will try to get my owners manual scanned and posted in here.
Sarge
Old Apr 27, 2009 | 06:49 AM
  #428
vettdvr's Avatar
vettdvr
The 2000 doesn't have the code on the box. I found the box but never found the code anywhere on the truck.
Old May 5, 2009 | 10:47 PM
  #429
EXv10's Avatar
EXv10
can't delete
Old May 6, 2009 | 07:16 PM
  #430
daddyd05x's Avatar
daddyd05x
Just found it on my 05 x and it was a piece of cake. Did not remove anything and with a long flex mirror and a good light I found the black box up towards the radio and the sticker was on top so I used the mirror and got the numbers. Tried them and they worked. Took about 2 minutes to get myself situated in the right position to see. I just went up by the gas pedal.
Old May 6, 2009 | 07:17 PM
  #431
daddyd05x's Avatar
daddyd05x
Thanks to everyone for all the great info on this. Without this I probably would have paid the dealer a ton of money for the code
Old May 6, 2009 | 07:33 PM
  #432
EXv10's Avatar
EXv10
The 2000 and I think the 01 doesn't have it anywhere on the truck but some say it is behind everything on the gem box on the left of the steering wheel. You can print out that code; Weak security in our daily lives@Everything2.com
and it should take 20 minutes or less to find it by punching the #s......Click on the word "weak".
Old May 6, 2009 | 08:10 PM
  #433
topgun35's Avatar
topgun35
my 05 x was up behind where the ashtray would be up in the dash towards the driver side
Old May 7, 2009 | 10:32 PM
  #434
TX Silver's Avatar
TX Silver
Got tired of looking, so I started on the sheet. I modified it so that I could enter the codes 35 at a time (since that's the cutoff for the anti-theft feature). Got lucky and found the code after five lines. Unfortunately it's the code programmed by the previous owner. I guess that will work until I go through the rest of the numbers.
Big thanks to whoever thought to put that list together.
TX
Old May 7, 2009 | 10:47 PM
  #435
EXv10's Avatar
EXv10
TX
Great! I would leave well enough alone. You have to erase your code and then it requires the original code to program your own new code. But I guess you could find the original code after you erase this one and go from there.
