Exteror plastic bleaching
Old Sep 22, 2006 | 11:04 PM
  #31
PAPPYBALL's Avatar
PAPPYBALL
So the project used up 1 quart of base, and 1 quart of clear?
Old Sep 23, 2006 | 08:25 AM
  #32
corvettej's Avatar
corvettej
Trailering
Smile
If your expy in still under warranty, Ford will will replace them if they are faded, I complained to my dealer and they took pictures, email them to ford. Ford gave them the okay, they order the parts and call me 2 weeks later to have them install. That was over a year ago and they still look great, but I do like the idea of having them painted.
Old Sep 24, 2006 | 01:00 PM
  #33
AF Mezkin's Avatar
AF Mezkin
pappy, yea all you'll need is a quart of each. That should be enough for the job, you might have some left over.
Old Sep 25, 2006 | 09:39 PM
  #34
PAPPYBALL's Avatar
PAPPYBALL
Mezkin, thanks for all the info, this is a project i am defiantly going to tackle soon.
Corvette, unfortunately my truck is out of warranty, and even if the panels weren't painted I would still do it, I like the look of the matching color all the way around MUCH better.
Old Sep 26, 2006 | 06:46 AM
  #35
corvettej's Avatar
corvettej
Trailering
Thumbs up
Painted, I agree they do look a 100 percent better.
Old Sep 26, 2006 | 07:33 PM
  #36
AF Mezkin's Avatar
AF Mezkin
pappy,
Some helful hints; follow all mixing directions, dry times between coats, dry time between base and clear and most of all take your time. A paint job is as good as the prep that is done prior to the appilcation of the base and clear.
Make sure your panels are very clean and free of any grease or wax, you might want to use a plastic safe degreaser/cleaner. Use "plastic adhesive promoter/primer" and flex additive in the clear coats.
Good luck pappy
Old Sep 27, 2006 | 09:16 PM
  #37
KrAzYKARL's Avatar
KrAzYKARL
did you have to sand them smooth first? because they come with that rough texture and i would think that they wouldnt be smooth after painting them.
-thx
Old Sep 28, 2006 | 04:47 PM
  #38
AF Mezkin's Avatar
AF Mezkin
No I didn't sand them, thats why I applied the multi coats of base and clear. With no sanding the panels are very smooth.
Check out my galleries for close up pics of the panels and judge for yourself.
Old Sep 29, 2006 | 09:43 PM
  #39
KrAzYKARL's Avatar
KrAzYKARL
sweet, looks good.
Old Sep 29, 2006 | 10:08 PM
  #40
ReAX's Avatar
ReAX
If the plastic is just fading, try mothers preserves and back to black. It made a real difference on my bumper and tailgate handle. I applied two coats of preserves with a tooth brush, a coat of back to black with a tooth brush and another top coat of preserves. It does wonders on all plastic and rubber trim.
Old Oct 21, 2006 | 01:20 PM
  #41
97 WS6 T/A Conv's Avatar
97 WS6 T/A Conv
AF, Your truck looks awesome like that! Much better than the stock moulding color/non color.
Mine is fading badly I need to get in before the warranty ends at the end of Decemeber.
frisbeeguy
2009 - 2014 F150
May 10, 2012 01:17 PM
bleach1012
17
Feb 2, 2011 09:44 AM
oldgoat49
Garage & Workshop
Jan 4, 2008 02:44 AM
equium
General Automotive Discussion
32
Jan 18, 2007 11:21 AM
diamkirk2001
Jul 13, 2005 12:51 AM
