Dash pad removal
Old Jul 31, 2006 | 09:53 AM
76F250Gal's Avatar
76F250Gal
Dash pad removal
Hi guys, I've read quite a few threads where people are replacing their dash pads and your removal instructions are very helpful but they typically say see the replacement dash pad for the bolt locations. I need to pull my dash pad to dye it and then i'm going to put it back in. Can anyone help sort of describe where the bolts will be found since I don't have another pad to reference? Thanks guys!!
Old Jul 31, 2006 | 10:03 AM
78f-150Supercab's Avatar
78f-150Supercab
I just removed mine and from what I recall there are eight total bolts. Two on each far side, one above the glove box, one above the gauges and two in the middle (one is parallel to the ground coming out of the middle dash piece that goes down the dash a little). You'll need to remove the glove box and gauges, and move the vents around to get to the bolts. You might need to remove the heater/stereo too but I'm not sure. Good luck!
Old Jul 31, 2006 | 10:24 AM
98cobra1064's Avatar
98cobra1064
I was able to do it without pulling out the radio and heater controls. But I did have to pull everything else out.
Old Jul 31, 2006 | 11:12 AM
F1rocco-NY's Avatar
F1rocco-NY
Great time to paint the dash and or clean up the wires...Maybe 100mph speedo..Easy enough to do...I just always seem to put it off....
Old Jul 31, 2006 | 03:08 PM
Alvin in AZ's Avatar
Alvin in AZ
Yeah like F1rocco-NY said, take the whole thing apart take the dash out and paint it and cover the inside with Super Dynamat too. Then leave off the silly dash pad. Ok that's what I did, YMMV.
When I did that I found the source of the "cricket" sound the dash made for about 10 years... a bolt left out of the driver's side.
And oiled my windsheild wiper mechanism when the dash was out and re-foam covered the flapper doors and a couple other things. Oh yeah, got the dead mouse out of the vent system too.
Alvin in AZ
('75 F150 360 T18 no chrome or radio antenna to get ripped off by brush
Old Jul 31, 2006 | 03:31 PM
Mil1ion's Avatar
Mil1ion
Re-dying with proper Vinyl Dye ...will provide a much longer lasting finish than "painting" it will.
Old Jul 31, 2006 | 08:26 PM
cujo8's Avatar
cujo8
Mil1ion, where is a good place to get the Vinyl Dye? I picked up a blue dash pad and I need to dye it Tan (saddle). Thanks.
Jim
Old Jul 31, 2006 | 08:29 PM
78f-150Supercab
I used Duplicolor's vinyl/fabric dye and it works great. Very durable.
Old Jul 31, 2006 | 09:32 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Most auto paint stores can mix the interior color in paint, and they also have stuff they can color mix for applying to vinyl.
Make sure to prep the area really well. Clean and free of contaminants etc...
Old Aug 1, 2006 | 08:00 AM
F1rocco-NY's Avatar
F1rocco-NY
Some places offer a free Dupont color picture matching thing...They can take pic of your door panels and match it with the "Exact" color...Usually a $25 fee....If painting or dying is your choice...the pad is easy to take out...Im thinking nine nuts...Same size as your heater core box...If you got A/C.Hint....
Old Aug 1, 2006 | 11:41 AM
Mil1ion's Avatar
Mil1ion
Auto paint store have all the original colour & mix codes.
They can mix Vinyl dye ever bit as easy as paint.
The DYE is a different product than paint.
It can be applied the same way but the preparation materials are different depending on what you are dying.
Plastic vs Yinyl.
Plastic prep vs Vinyl prep
First : For a cleaner I use lacquer thinner.Make sure you wear a mask and do the work in a well ventilated area.
I have dyed several Mustang interiors with total success using vinyl dye using The "PREVAL" application system.
http://www.prevalspraygun.com/
It's well worth the money.
This system allows one to paint or dye several different colours/projects.
shortwide
15
Aug 30, 2014 02:04 PM
Ripcity
Sep 30, 2013 07:36 PM
robb040
Appearance & Dress-Up
Apr 19, 2013 06:41 PM
weaver79
Jan 27, 2011 05:37 PM
Rick_Fury
Nov 8, 2010 12:40 AM
