Oh, Im also about to remove and replace the factory dash pad.
Destroyed by 31 years of weather. I noticed there were a couple of bolts/nuts, is that it?
Thanks
A few? There should be around a dozen nuts you have to take off. If you feel something still tugging, check again near the tug regoin... The dash pad should come off without any problems once it's undone (nuts are all off).
Should be some at each end of the pad, along the middle of the pad and on one or two in the front middle of the pad where it comes down and slips over the front. Tiny hands are helpful. Be real nice to your better half, and maybe she'll help out.
For what it's worth (and if memory serves), there are also a few smaller nuts that are in the metal dash part close to the window that don't have to come out...
When I replaced my dash about a year ago I took every nut and bolt out that I could find (and still missed a few!) but later realized I wasted a bit of time on some that didn't.
Easy thing to do is to look at the new one to get an idea on where the old one are located, alot of it is by feel, and sometimes a VERY difficult feel.
I took mine off yesterday. I had 8 nuts to remove. They were a 9/32 socket. There are 2 nuts nearly side-by-side on the far left and far right. There are 3 spaced out across the front and 1 on the little piece that dips down in the middle front.
.___.___.___.___.
'_______,_______'
The periods and apostrophes kinda make the pattern....
