Stiff shifts
Old Jul 9, 2006 | 09:57 PM
beeker's Avatar
beeker
Smile Stiff shifts
I have a 1970 f100 302 4 speed.
The shifter is very hard to manouver, hard to find gears.
Is there an aftermarket shifter available or do i need to upgrade the transmission
to get better responce.
I am trying to keep the appearance of the truck stock but would like to upgrade the componenets to give the truck a better feel.
Any advice or help would be greatly appreciated.....Beeker
Old Jul 10, 2006 | 05:29 AM
jowilker's Avatar
jowilker
beeker, Welcome to and the 67-72 forum.
Does your clutch seem to be disengaging properly?
John
Old Jul 10, 2006 | 10:14 AM
beeker's Avatar
beeker
Smile
Hi there, well I just got the truck so i dont know all the quirks yet.
there does seem to be a slight chatter when i down shift not quite as smooth as
i think it should be. I have been driving newer trucks for the last 20 years, so i really am not sure what i should be feeling in the old beast. thanks for your time
Colin
Old Jul 10, 2006 | 05:32 PM
Ford_Six's Avatar
Ford_Six
Those old four speeds have a really long throw, there's not much you can do about that. The tranny should be filled with 50wt motor oil also, if it has gear oil in it, that will make it shift harder.
Old Jul 10, 2006 | 08:49 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
If you cut down the length of the shift levers on the trans (cut a section out) then reweld for a shorter shift pattern, oil stone and polish all internal parts of the transmission, set up all synchro clearances on the below the tight side of spec, run spherical ball end linkage with a tight rebushed shifter. When everythings set up correctly with a clean releasing clutch you should have a smooth fast shifting box that's clean and positive as newer boxes. Try different brands of gear oil, you'll feel a difference.
All the above applies to equipment that is in good condition not a loose high mileage beater transmission.
.....=o&o>.....
Old Jul 11, 2006 | 08:31 AM
beeker's Avatar
beeker
thanks 4 your time
Old Jul 11, 2006 | 08:39 AM
390fe's Avatar
390fe
Keep in mind first and reverse gears are not synchronized. The proper gear oil is important to proper shifting. Byond that, your transmission could need new synchronizers installed.
Old Jul 11, 2006 | 09:02 AM
"Beemer Nut"
I'm thinking you have a NP 435 or T-18 box, forget about the external shift linkage posted above. Make sure the aluminum shifter top, fork pads, input shaft and synchro clearances are set correctly and in good condition. Worn or missing fork pads will cause crappy shifting as well the above worn out parts. If you have the newer type of shifter with O rings on the end for noise and vibration reduction those levers cause more trouble than they cure. Remove the O rings, clean then epoxy the assembly solid. If you live in a area that get cold think about different thinner oils in the box as they become beasts to shift with those large gears. Buy all new with the clutch, pilot bushing included as reman crap is loose crap and will cause chatter.
.....=o&o>.....
Erik Peterson
Mar 3, 2014 05:49 PM
barrett74
Jul 6, 2012 10:41 AM
HYDAFL
2004 - 2008 F150
33
Mar 14, 2007 05:37 PM
rumblinbass
Jun 5, 2001 05:13 AM
