Sponsored by: Real Truck
Mounting air compressor
Old Jul 8, 2006 | 05:31 PM
Zergee's Avatar
Zergee
I am about to buy a Viair 450 c air compressor and want to mount it on my '06 250 diesel. Well those of you with diesels know there isn't much space left under the hood. So where do I mount this thing and do I just wire it to the 30 amp up-fitter switch? Advice much appreciated
Old Jul 8, 2006 | 07:09 PM
BobbyDiesel71's Avatar
BobbyDiesel71
I have a 450C as well
I am thinking of mounting it under the truck, along a frame rail or in a toolbox.
Keep me up to date and post all pics, I will do the same
Old Jul 8, 2006 | 07:10 PM
BFR250SD's Avatar
BFR250SD
On my V10 I am barely able to put my ARB compressor under the hood.
Most folks that run a compressor and tank as large as most of the VIAIR setups put them in a tool box in the bed or under the rear seat in the cab.
As far as the wiring, it should come with all the necessary wiring. I've never been a big fan of tapping into the factory wiring on items that can be high draw or high current. I have a whole seperate power block that I have the accessories (minus the winch) hooked up to on a 100 amp fuse. Then all of them have their seperate fuses.
Just go to radio shack, best buy, circuit city, etc and pick up an amplifier power kit and it'll come with all the items I was mentioning. Thn you can add a power block that has as many outlets as you need.
Old Jul 8, 2006 | 07:21 PM
BobbyDiesel71
can you post some pics of the power tap you have
thanks!
Old Jul 9, 2006 | 08:33 AM
BFR250SD's Avatar
BFR250SD
Yup! I'll grab a few pics when I get home later on today.
Old Jul 9, 2006 | 10:27 AM
BobbyDiesel71
Thanks
you are the COOLEST!!!!!!!!
Old Jul 9, 2006 | 12:02 PM
darth_calvin's Avatar
darth_calvin
I've got my compressor mounted inside a slightly modified battery box on the passenger side frame rail right below the front door. The tank is mounted passenger side under the bed. And I have it wired through a relay direct to one of the batteries. I don't have upfitter switches (maybe some day) but I did install some really nice rocker switches from a Western Star for the compressor and horn. I just got pics of it and am going to try to set up a gallery... finally.
Matt
on edit... I just finished setting up my gallery, so you can see pics there.
Old Jul 9, 2006 | 02:25 PM
BFR250SD's Avatar
BFR250SD
Ask and yee shall receive!
Here is how my power is layed out:
One wire from battery to fuse-----Fused power to distro block------Distro block to accessories.
https://www.ford-trucks.com/user_gal...id=121986&.jpg
https://www.ford-trucks.com/user_gal...id=121987&.jpg
https://www.ford-trucks.com/user_gal...id=121988&.jpg
The other power wires that you see on the battery are the power for the front and rear winch.
The only things I want to add is a solenoid that I can control in the cab and shut down all power, if needed. Basically a big kill switch. And also a second battery (Optima Yellow Top) that I'll run just the winch from.
TNT in Round Rock's Avatar
TNT in Round Rock
I'm about to do the same thing. You just turn the air compressor on and off ? Or do you have a pressure switch to maintain your tank pressure ?
Old Jul 9, 2006 | 02:33 PM
BFR250SD's Avatar
BFR250SD
Most of those have a pressure switch in them and you just let it run automatic. Dangerous not to have it.
My ARB has the pressure switch for running constant and a power switch in the cab to turn it off when I don't need it, which is most of the time.
https://www.ford-trucks.com/user_gal...oid=92331&.jpg
Old Jul 9, 2006 | 03:13 PM
darth_calvin
I have a pressure switch on mine, but I also have the on/off switch on the dash.
BFR, where did you get your switches? Do you have the plugs to plug into the back? So you can unplug your switch without doing each wire individually? I have the same switches which I got from work, but the only plugs we have are attached to the wiring harnesses already which are all built in Mexico or someplace.
Matt
Old Jul 9, 2006 | 03:16 PM
Neil's Avatar
Neil
I mounted my compressor on the right frame rail, under the bed, right behind the cab. I had the machine shop cut and bend a piece of 1/4 steel plate to bolt to the frame for the compressor to sit on. I did NOT need to drill any additional holes in the frame to do the install. There is a few pictures HERE. Since the photos were taken, I've covered the compressor with a modified battery box, and relocated the air intake filter.
Old Jul 9, 2006 | 05:09 PM
BFR250SD's Avatar
BFR250SD
Matt
Mine all came with the ARB's. The wires plug in individually. Anything that comes with a proprietary harness..........GETS CUT. I hate having to get some special friggin part for a simple task (i.e. a relay). I can't stand when a relay goes or a fuse blows and you have to buy thier stuff. I just cut it and wire it up with common pats.
Jsgilliam
Sep 14, 2013 06:22 AM
A/Ox4
Jun 6, 2011 02:34 PM
Richie.Rich
Oct 20, 2010 07:04 AM
IZZYAZ
Apr 10, 2009 10:46 PM
grouch
Nov 12, 2003 07:28 PM
