Lower cab mount problem
Old Jun 17, 2006 | 08:42 PM
f100tk77's Avatar
f100tk77
I have a 77 F100 stepside 2 wheel drive that my son and I are rebuilding. It has been a long process as we have never attempted a project this size. Today we removed all the cab mounts but the front lower cab mounts were rusted underneath the rubber mounts. The rust enlarged the hole to the point the rubber mounts can almost be pulled through. I would like to drill out the rivets and bolt in new mounts. I have looked all of the sponsor's site with no luck. (Blue Oval, Bronco Graveyard, LMC, NPD, Dennis Carpenter) Is my only choice to have to have the originals repaired? Only the top is bad. Thank you for any help you may be able to give us. This site has been a big help to us. Maybe some day we can return the favor.
Old Jun 17, 2006 | 09:16 PM
mark a.'s Avatar
mark a.
As far as I know nobody reproduces them.
Old Jun 18, 2006 | 12:43 AM
WrenchHead84's Avatar
WrenchHead84
Get ya a nice mig welder, and some sheet metal roughly the same thickness and make your own. I've have to make floor pans for other vehicles. So long as you have a welder, a way to cut and grind. You can do anything you need.
Old Jun 18, 2006 | 02:50 AM
bucks77ford's Avatar
bucks77ford
Thumbs up
I looked all over too. Its one of those parts that were not reproduced because they were never intended to be replaced. you could look at a salvage truck, but you can't tell if a mount is rusted until you get the cab off and then the rubber bushing.I had the same problem with the truck i am restoring. I took 1/8 inch steel plate, and used a drill press, hole saw and made my own. Then welded the plate on top of the mount. Turned out pretty good. I believe I used an 1 and 3/4 hole saw for the mounting hole. I have a highboy chassis, so I really had no choice but to repair those. I do have some pictures in my gallery if you want to look at. It took some time to cut out the plates. Have to move real slow and use some cutting oil. You can use a torch also, but it's hard to have nice exact holes. Hope this helps.
Old Jun 18, 2006 | 05:54 AM
buck_'s Avatar
buck_
I am in the middle of doing this exact thing on my 78 F250. The mounting points are 9 gage steel. I don't have the measurements for hole size off hand but could get them if you need. I removed the mounts from the frame dipped them to remove all rust. I had a couple of cracks in the rear cab mount/frame brace to weld up as well. Besides this way I can get all the rust off of the parts and the frame, seal and paint before I put it back together.
Good luck with your project
Buck
Old Jun 18, 2006 | 01:13 PM
f100tk77's Avatar
f100tk77
Thanks for the help and the pictures. I will get busy and gather the materials. What grade of bolt did you use to replace the rivets?
Old Jun 19, 2006 | 05:04 PM
Hyperactive460's Avatar
Hyperactive460
try mtsalvage.com . thats where i got mine. used but rustfree......i also got my rear upper shock mounts and rear cab support from mike...i have pics in gallery
Old Jun 19, 2006 | 07:08 PM
buck_'s Avatar
buck_
I plan on using grade 8 bolts and nuts. After everything is in and tight I plan on spot welding the nut and bolt together. That way I know it will never back off.
Buck
Old Jun 19, 2006 | 07:23 PM
poppe's Avatar
poppe
Your talking about the cab mount brackets right? if so i bought some from here check it out http://www.73-79fordtrucks.com/framedept.html
good luck
Old Jun 20, 2006 | 09:05 AM
bucks77ford
I used grade 8 bolts. I drilled holes out to 1/2 inch and then used grade 8 1/2 x 1 1/2 frame bolts with lock nuts. It took me about 2 hours to repair all four of my brackets.
Old Jun 20, 2006 | 05:47 PM
Hyperactive460
i paid 100 bucks for the two front frame perches and the rear cab support including shipping
Old Jun 23, 2006 | 02:06 PM
f1panel's Avatar
f1panel
mounts
I ended up making mine, just make them heavy enough.
Old Jun 26, 2006 | 08:00 PM
f100tk77's Avatar
f100tk77
Thanks Poppe. I placed my order today. They rebuild the original mounts. Also thanks to Buck for his pictures and also the bolt info. 73-79 Ford Trucks suggested that I torch the head off of the rivit and then use ahammer and a punch to remover the rivit instead of drilling. After this is corrected, then off to the paint shop! Thanks for the help.
Todd
abe
13
Jun 13, 2014 12:39 AM
johaner78
Nov 7, 2007 09:46 AM
66 twin i
Jan 6, 2007 09:51 PM
Ed in Grayling
Jan 6, 2004 10:11 AM
inliner
May 19, 2002 05:11 AM
