Edmonds 2006 HD Pickup Comparison Test
And I would be quite happy to be shipped over there, but I don't think I can fit the weather or the beaches in my suitcase...
(not to mention my Ranger or my Pursuit ute)
Anyways, I digress...
The competition comprised the other two most common trucks found in these parts: the Ford F-250 powered by the Power Stroke 6 L V8 diesel making 325 hp and 570 lb.-ft. of torque. The other was the 2500-series Dodge Ram with the Cummins 5.9 L HO turbodiesel inline-six under the hood, putting out 325 hp and 610 lb.-ft. of torque.
Up against them was the new Duramax in the current 2500 Sierra/Silverado, but with an increased displacement to 6.6 L in a turbodiesel V8 configuration that offered 360 hp and torque of 650 lb.-ft.
once again look at how much more power it makes and for the small margine it won the test by it doesn't impress me one bit. fords the biggest heaviest truck by far. not to mention the least ammount of power and its right up there between the chev and dodge. the new 6.4 is gonna make that chevy look like a kids toy
I hope you're correct.......and I also hope the newest PSD at least matches the Dmax in lack of NVH.
One of the couple reasons I don't like diesels in general is because of the noise.....the 6.0 is miles ahead of the 7.3, and the GM is smoother/quieter than the 6.0.
Before this all starts up again, I know that the overall diesel feeling is a subjective one....and that some LOVE that total experience.
To me, to have almost the powerband/smoothness of a gasser with the overall power/torque of a TD is the perfect combo........the Dmax comes closest to those parameters AT THE MOMENT.
But I still wouldn't buy one because I don't like the rest of the package.
Having 5-6 injection events per cycle will make it substantially smoother and quieter. Not to mention the abscence of the HEUI's inherrent rattle.
Whether it actually IS quieter though... I don't know.
If you guys have honestly driven the NEW Dmax with 6 speed and still think it has lag.......I'd HATE to hear what you call the 6.0 or 7.3's responsiveness.
I just came back from a call........I'm chuckling at what some consider performance....the 7.3 PSD's are SLUGS in our rescues!!! I was trounced by a 1/2 ton Avalanche pulling a ski boat while driving the rescue....sad part was I don't think he knew I was racing!!!
I've driven the 6.0's.......again, off the line (maybe to 40-50) I'd happily take my V10 over the 6.0..........after that, I'm toast.
The current Dmax (not the old ones) is as close to a gasser as any diesel I've ever driven..............maybe it is a freak. Maybe the one Edmunds tested was too.
You better check with Polarbear on that one........he actually pulled 'em side by side.............the lowest points were on the Ford!!! No, not the crossmember.........if I remember, it was the radius arm mounts were lower on the Ford than any point of the GM.
That's a moot point though..........the only thing I think that's superior on the GM is the powertrain............here's hoping the 6.4 PSD changes that.
The Dmax 6 speed Allison is the only current diesel in a light duty truck that would make "me" consider switching from a gasser. And yes, I think 80 feet pound of torque is HUGE when it's a stock warrantied rating.
And I heartily and confidently disagree on the ground clearance issue. I'm not sure what a "radius arm" is but if I'm not mistaken it's a part that is located between the front wheels and therefore not a challege to my claim.
I've put 'em side by side too and used a measuring tape. Again, the lowest item between the axles on both trucks is is the transfer case crossmember. It is very clear to see.
Ford has low parts that hang down up front but they are in position to be carried over breakover type obstacles by the wheels/axes. In other words, a GM truck has an advantage in being able to straddle things like tree stumps because it has IFS.
I'm speaking from experience when I say I owned a 2001 Silverado 1500 that could not go places my F250 does easily and the 1500 rides higher than the 2500HD. One place that comes to mind is a creek that I cross on my own property. Driving up over the creek's bank my Chevy's frame and crossmembers would get hung up and scrape the edge of the bank after the front wheels cleared the edge of it. If I was willing to crunch the gas and endure the grinding sound as my Chevy skidded over rocks maybe I could make it. Sometimes not.
On the other hand, my F250 crawls right down into and back out of the same creek without it's frame or anything even contacting the ground. The Ford's SFA is always going to lose a few inches between the front tires but for most situations the front tires are going to carry that stuff with them so it won't ground out. Both trucks are/were ext cab short box 4x4s.
1. According to GM's marketing surveys, something like 75% of all full-size pickups never leave pavement, so off-road capability just isn't high on GM's priority list. Like it or not, on-pavement ride and drive is what the Silverado is designed to shine at.... and I personally think it does.
2. Turbo-lag in a D-max?
Ummmm..... no. If there was, it wasn't a healthy motor.3. Whatever the merits and disadvantages of the various powertrains, we're all buying a truck- not just an engine.
Definetly agree on your last point polarbear, unless there is a HUGE HUGE difference in motor performance, people are going to buy what they feel most comfortable in, like the appearance of,etc, as i'm pretty sure no one really NEEDS a 350+hp diesle engine in a 350.
