No reverse lights
Old Jun 6, 2006 | 07:50 PM
86beater's Avatar
86beater
No reverse lights
I've got an 86 f150, 302, 4spd manual, regular cab.
My reverse lights dont work. I've checked the wiring and it all seems fine, replaced bulbs, checked fuses.
Could it be my back up light switch?
Also, where is said switch? I can't find it.
Thanks for any help.
Old Jun 6, 2006 | 08:02 PM
GLR's Avatar
GLR
It should be in the transmission. Look for a couple of wires or harness going towards trans.
Old Jun 7, 2006 | 12:00 AM
86beater's Avatar
86beater
Thanks, I've found one wire, that goes to the top of the tranny near the shift linkage, its got a round rubbery boot with some sort of circular electrical connection.
Would that be it?
Old Jun 7, 2006 | 12:30 AM
big hoss 29's Avatar
big hoss 29
Yup, that is the back-up switch.
Old Jun 7, 2006 | 05:17 AM
srercrcr's Avatar
srercrcr
You might switch fuses with another location. I've seen a fuse look OK but not be OK.
It's usually the simple things.
Old Jun 7, 2006 | 12:23 PM
86beater's Avatar
86beater
I'll try that, thanks! Although that cant be it because when I did take the electrical connection off the switch i accidentally touched the tranny with the lead and it sparked really good.
I'm thinking its gotta be that switch because there is power there.
Old Jun 7, 2006 | 02:46 PM
Piffery1's Avatar
Piffery1
When it sparked you probably blew the fuse, so now you may have two problems. I think its Fuse #5 (15 A.).
Old Jun 7, 2006 | 04:34 PM
86beater's Avatar
86beater
Sure enough, it was the switch. Had a small amount of fluid in the switch and electrical connector, might've been shorting or a dead switch. Lights work perfect now.
$14 and I'm happy.
Eman1022
13
Apr 25, 2014 09:23 AM
cray0971
Aug 25, 2011 08:46 AM
atccracing
Jan 12, 2011 09:11 PM
BlueOvalBud
Mar 3, 2010 08:53 PM
Eboda
Bronco II
Jun 8, 2003 11:04 PM
