Engine will crank.. but doesnt start
Old Jun 7, 2006 | 02:47 PM
4x4-Ford-4x4's Avatar
4x4-Ford-4x4
Question Engine will crank.. but doesnt start
hello i am seventeen and i own a 1985 F-150 with a 300 i-6 motor. The other day i was driving down the interstate when my fuel pump broke i got my truck towed back to my house and i replaced the old fuel pump ..thinking that my truck would run again... when i turn the key the engine cranks but it will not start ..even when i pour fuel into the carb.( i noticed the new fuel pump wasnt pumping in fuel but that is because it is not primed). I need all the expertise i can get if u have any ideas please comment .. im completly stumped
Old Jun 7, 2006 | 03:07 PM
Kemicalburns's Avatar
Kemicalburns
dont have to prime a mechanical fuel pump. check your fuel filter. make sure you are getting spark to the plugs as well.
Old Jun 7, 2006 | 03:18 PM
Nathane's Avatar
Nathane
u need 4 things for theese trucks to start
Air, fuel, spark, and spin
You say its turning over, is it going at a normal speed (or slower?)
How's the airfilter?
Have you tried starting fluid?
Check the spark plugs and wires, if they're origional, they're most likely SHOT
good luck with your truck
~Nate
Old Jun 7, 2006 | 04:25 PM
4x4-Ford-4x4
which wires do i check, how do i check them.. also do you mean looking at them to see if there fowled? you for youre input
Old Jun 7, 2006 | 05:52 PM
big hoss 29's Avatar
big hoss 29
Take the coil wire off of the distributor and place it near but not on the center post on the distributor where you took it off. Have a friend look to see if there is a spark coming off of the wire to the post. It's best to wait until it's almost dark out to see anything.
As far as your fuel pump, are you sure the fuel guage is right? If you have dual tanks, try switching to another tank and see if the fuel pump pulls fuel. I know it sounds stupid, but Ford sending units are famous for being wrong. On my truck, the front tank reads 3/4 full until it's just about empty while the back tank reads normal.
