Reverse lights not working
Old Apr 24, 2014 | 08:55 AM
Eman1022's Avatar
Eman1022
I have a 81 f100 ranger and my reverse lights don't work anymore, I've checked the bulbs and they are still good and the switch looks to be good, what else could cause the lights not to work?
Old Apr 24, 2014 | 09:05 AM
reamer's Avatar
reamer
Now sure what "looks good" means.
Did you test with a meter?
Is there 12v on 1 of the wires (KO EO)?
Continuity test on the switch?
Broken/corroded harness?
Old Apr 24, 2014 | 09:09 AM
Eman1022's Avatar
Eman1022
Yea it was tested with a meter and it had good current, and I'm not sure if their is a 12v on the wire and I have not done a continuity test yet
Old Apr 24, 2014 | 09:23 AM
reamer's Avatar
reamer
This is a good start for you. Kinda like "follow the electricity" If voltage is getting from the battery past the switch, follow the wire right to the sockets.
Old Apr 24, 2014 | 09:31 AM
Eman1022's Avatar
Eman1022
How do I go about checking the wire through out to see if their is a break in the current
Old Apr 24, 2014 | 09:43 AM
reamer's Avatar
reamer
As Ford states, "use a pin to pierce the insulation to check voltage"
I usually will go to the end of the circuit and test the plug.
If the front end of the circuit has power and the end of it does not, visually look down the wire (you have to twist it to see the other side for chafing).
If no luck on finding a break, start using the pin method.
Old Apr 24, 2014 | 12:30 PM
Gary Lewis's Avatar
Gary Lewis
Reamer is on the right path. But those lights usually fail due to a bad ground.
Old Apr 24, 2014 | 12:47 PM
reamer's Avatar
reamer
Oh yeah, the ground thing
Old Apr 24, 2014 | 04:49 PM
Eman1022's Avatar
Eman1022
Alright, I'll check the grounds first and see if that's the problem
Eman1022's Avatar
Eman1022
Thanks guys!
Old Apr 24, 2014 | 07:24 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Ain't that the truth.......
Of course, the grounds in the sockets for reverse, and stop/turn/tail & front marker/turn are known to be rather poor. The little metal tab that is supposed to contact the side of the bulb base can get bent and/or corroded after this many years.......
Old Apr 24, 2014 | 07:44 PM
Franklin2's Avatar
Franklin2
Most testlights have a very sharp point on them to poke the wire, they are better for checking light circuits than a digital voltmeter.
Have you checked the fuse?
Old Apr 25, 2014 | 08:49 AM
Eman1022's Avatar
Eman1022
Yea I've checked the fuses and all of them were good, I even replaced the one for the lights and nothing changed
Old Apr 25, 2014 | 09:23 AM
ctubutis's Avatar
ctubutis
Well, if you have a meter, do like was said and follow the electricity... test for power on the incoming side of the switch, then the outgoing side of the switch once the switch is activated... then at the other end of the wire that connects to the outgoing side of the switch... then to the socket, then to ground.
Batman7593
17
May 19, 2014 07:30 PM
cabloom300
Oct 22, 2012 08:15 PM
little truck
1983 - 2012 Ranger & B-Series
Oct 10, 2008 01:28 PM
TimMcGraw67
Mar 17, 2005 10:06 AM
checkyoursix
May 12, 2004 01:49 PM
