Reverse Lights not working
Old Jan 12, 2011 | 03:10 PM
atccracing's Avatar
atccracing
I can't find a schematic for my reverse lights. I checked the bulbs, and I don't seem to be getting power (checked with my test light) at the socket. I tried swapping in a new neutral switch, because I was told the reverse circuit was part of that switch.
Any help would be apprecciated!
1994 Ford F250 5.8L C6
Old Jan 12, 2011 | 05:19 PM
rjitreeman0909's Avatar
rjitreeman0909
Depending on transmission, backup light switch may be on transmission.
Old Jan 12, 2011 | 09:11 PM
1988_F150's Avatar
1988_F150
Not listed but did you check the fuse? From there you are going to need a schematic and start verifying power to the reverse switch. If you have power there find the next splice in the wire and check again there, working your way back. Don't forget to also verify you have a good ground at the reverse lamp sockets.
Good luck.
E55 Bulldog
Mar 24, 2016 10:21 AM
Seanosu
Mar 7, 2016 09:59 PM
Jmatthews
May 20, 2015 04:22 AM
mikeyt4e
Mar 7, 2015 05:12 PM
cray0971
Aug 25, 2011 08:46 AM
