Grill assembly
Old Jan 15, 2002 | 05:01 PM
CRJ900's Avatar
CRJ900
Grill assembly
Couple of Questions for you.
1.What is the best way to take off a grill on a 68, 360cid. I saw some bolts underneath but there kinda hard to get too.
2.Can i sandblast this, then paint it with some special paint when i remove it. It looks to be hard steal. Is it reccomended?
Old Jan 15, 2002 | 06:35 PM
mk's Avatar
mk
Grill assembly
Not hard at all to pull that grill off.It's easiest to pull it off with the upper 'shelf' with center brace and hood latch bracket attached. There are bolts up the front of each fender and one each side under the headlight doors plus a few others at various places you'll see. Be careful with the sandblasting as not to pit it too badly. If you want durability, you might think about powdercoating.
Old Jan 15, 2002 | 06:56 PM
CRJ900's Avatar
CRJ900
Grill assembly
I just want it too look good and last a long time. I want it to be very chromy. I would i go about powercoating?
Old Jan 15, 2002 | 07:00 PM
flyboy2610's Avatar
flyboy2610
Grill assembly
Powdercoating is a special process that needs to be done at a shop. It's not something you can do at home. But it is very durable.
Old Jan 15, 2002 | 07:34 PM
CRJ900's Avatar
CRJ900
Grill assembly
Have any of you ever painted a grill before. If so what type of paint and how did u prep it.
Old Jan 16, 2002 | 05:35 PM
6t8's Avatar
6t8
Grill assembly
Here is mine painted black on my 68...
http://www.island.net/~gjones/grill.jpg
the back end looks like this:
http://www.island.net/~gjones/back.jpg
I had to lighten the scans a bit to show the black grill but it shows kinda what it looks like
Gary
Old Jan 16, 2002 | 06:09 PM
Mil1ion's Avatar
Mil1ion
Grill assembly
Do you need some help finding the cropping tool on your scanner ?
We can help.
Dennis
Oh....Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
Old Jan 16, 2002 | 06:15 PM
CRJ900's Avatar
CRJ900
Grill assembly
yea thats cool, how did u prep it.. sandblast.. sanding... I would paint my chrome. what type of paint / primer would i use for somethinglike this. tahnks
Old Jan 16, 2002 | 08:31 PM
CRJ900's Avatar
CRJ900
Grill assembly
[updated:LAST EDITED ON 16-Jan-02 AT 09:32 PM (EST)]heres a pic of my grill to give u an idea.
http://C:\unzipped\DCP_0151_1\DCP_0154.JPG .......it didnt work, how do i put pics on here.
Old Jan 17, 2002 | 08:54 PM
6t8's Avatar
6t8
Grill assembly
The black grill is a painted grill that replaced a chrome grill. If you cant find a painted grill probably sandblasting and using a good enamel paint would work.
Gary
Old Jan 18, 2002 | 01:41 AM
eclectix's Avatar
eclectix
Grill assembly
I like what you did with the minor exception
that I might go with a less glossy (i.e.
flat or matte) black.
I am under the impression, though, that
the stock steel (non-chrome, painted)
grilles are usually if not always white.
So, presuming you started with a white
grille, what specific steps did it take
or would one recommend to get to a final
black?
Starting with a white grille with
a little surface rust, I could take
a wild guess (and it is only a guess):
* sandblast to the metal, both sides.
* apply black primer
* apply N coats of black paint
(where N>= 2)
Can anyone comment? Thanks,
Steve
Old Jan 18, 2002 | 09:57 AM
buzzard's Avatar
buzzard
Grill assembly
CRJ, Ford didn't offer a chrome grille in 1968. They only offered painted steel and bright aluminum grilles. The aluminum grille emulated a chrome grille’s appearance. You asked about taking your grille off. There are about 20 bolts that hold it in place, some are very difficult to reach and chances are most pretty corroded from time. I found an air driven ratchet wrench invaluable in removal and reassembly of mine.
Now to refurbishing your grille, if you want “chrome” I wouldn’t paint with a chrome color paint, you’ll probably be disappointed with the results, especially considering the amount of work involved in removal and reinstallation. If you must have chrome, take it to a plating company and have it triple plated. It’ll cost you about $250-$300, but should last for 20 or 30 more years. If you just want to paint your grille, take it off, sand it with various grits of sandpaper, you might want to sandblast in tight places, but I wouldn’t sandblast the flat areas. Then prime with an epoxy primer and topcoat with polyurethane acrylic enamel. I’d try to stay away from spray paint, just from a durability standpoint.
Good luck.
Old Jan 18, 2002 | 03:24 PM
CRJ900's Avatar
CRJ900
Grill assembly
what color primer and enamel?
Old Jan 18, 2002 | 04:05 PM
buzzard's Avatar
buzzard
Grill assembly
Doesn't matter what color primer you use, just make sure it is not the same color as your top coat. If I were restoring the grille, I'd paint it the factory color...white. Although my if I really had my druthers, I'd have it chrome plated.
danev2's Avatar
danev2
Grill assembly
fire3110
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Apr 1, 2009 11:25 PM
76supercab2
May 28, 2004 09:57 PM
motobub
Exhaust Systems
Nov 15, 2002 05:05 PM
lunargreen
Sep 27, 2002 06:03 PM
Ginntonnik
1978 - 1996 Big Bronco
Jan 23, 2002 06:09 AM
