Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
99 Lightning Grill
Old Mar 31, 2009 | 11:47 AM
fire3110's Avatar
fire3110
99 Lightning Grill
I purchased a billet grill for a 99 lightning. I want to paint the existing grill and lower grill before placing the billet grill over it. How do I get the grills off? I looked at it and it does not seem like an easy task. Any suggestions.
Old Apr 1, 2009 | 04:23 AM
Stewart_H's Avatar
Stewart_H
Bottom grille is straight-forward and just unscrews. The top grille is a tad harder, but really isn't that bad. You just have to remove some of those plastic push pin thingies and unscrew that bad boy and you're good to go. It's really intuitive once you start to remove it because you'll see where it's attached and how to get it loose.
Stewart
Old Apr 1, 2009 | 08:43 PM
fire3110's Avatar
fire3110
Hey thanks, I will check it out. Looked a lot harder at first glance.
Old Apr 1, 2009 | 11:25 PM
Stewart_H's Avatar
Stewart_H
It's been a looooooong time since I removed my grilles to put in the '01 grille, but IIRC, the hardest part is fitting a flat blade screwdriver between the top of the bumper and the bottom of the grille to get to the plastic push pin thingies without scratching the bumper.
Stewart
78Fseries
Aug 8, 2006 09:09 PM
poffutt
1978 - 1996 Big Bronco
15
Apr 10, 2006 08:22 PM
HOTFOOT
Appearance & Dress-Up
Jan 24, 2006 03:16 PM
psubrian
Aug 19, 2004 01:00 PM
superduty_1
Sep 22, 2000 07:41 PM
