C'mon please help
Running straight 12VDC from a car battery typically won't make a spark plug work, not enough voltage. The actual amount of current running through a spark plug is something like 100 or 200 milliamps (1/10 ~ 1/5 of an amp) but 15,000 volts. You need voltage to fire a plug.
That being said, I reeeeallllyyyy hope you rethink this project. It'd be bad to have a backfire light off your fuel tank or something. It's just not worth it, imho :-X23
William in Atlanta
GROUNDED! Holding the plug with metal pliers is not a form of a ground. Take the spark plug, wrap a short bit of your 14g wire around the threads. Attach the other end of the wire to your frame or the - side of the batters. Now touch the tip of the plug that usually goes into plug wires to the + side of the battery. Now you'll see a spark, I guarantee it.
Does the choke thing really work? Is there enough gas left in the exhaust from the engine to ignite? It seems like you'd get much better flames if you rigged up a fuel injector upstream from the exhaust tip. But then again, it'd be even more dangerous.
Why not just attach some orage metallic tape to the exhaust tip so you can watch it flutter around and pretend you did all the work to set up a flaming exhaust?
>here.
>of a ground.
Of course it's funny when you miss the Exact wording.
While hold the sparkplug wire on the POSITIVE Post of the battery Hold the sparkplug with pliers (he was worried about getting shocked)
so it TOUCHES the NEGATIVE POST on the Battery*
THUS, GROUNDING the plug on the battery*
You should see a spark from the center electrode to the ground electrode when you do this.
Read closer before flaming ,Funnier Guy! :+
Here's a copy of the original post
20-Jan-02, 09:06 PM (EST)
Did you have the pliers touching the - negative post of the battery when you did this?
Center electrode top of plug to positive post while
touching Threaded part of plug to the negative post.
WATCH FOR A QUICK SPARK everytime you do this!
Dennis
Dennis
Oh....Please Don't Ask Me Any Tough Questions As:
"I'm Saving Up MY Memory For When I Develop Alzheimer's"
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=144&.jpg
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=143&.jpg
78 F-150 429CJ C6 ,Silver w/Explorer Pkge
641/2 Mustang,Pre-World's Fair Car #8092
64 Fairlane S/C waiting for a 390-4spd.
68-Mustang.Sunlit Gold 80,000 miles
