Sponsored by: Auxito
'97 4x4 After recall problems
Old Jun 3, 2006 | 01:44 AM
Oh_That_One_Guy's Avatar
Oh_That_One_Guy
during the recall process of the cruise control i was having problems with my display fuse (5 amp) blowing every now and agian. after they turned my cruise control back on, it blows constantly. i have no speedomiter, fuel, rpms, *odomiter* (only plus in the bunch) but i don't know what to do. dealership wants more $$$ to look at it. b/s i say. any ideas.
Old Jun 3, 2006 | 08:51 AM
projectSHO89's Avatar
projectSHO89
There is no connection between the circuits worked on in the CC recall and your problem.
Old Jun 19, 2006 | 02:38 PM
BTAAA's Avatar
BTAAA
I just had same problem. Mine ended up being a short to ground in the reverse lights, which runs off same fuse. A/C clutch also runs off this fuse.
Old Jul 22, 2006 | 06:12 PM
IofOsiris's Avatar
IofOsiris
I am having the same problem when I shift into 1st 2nd or N, entire display dies. I'm constantly replacing that 5 amp fuse. Does anyone have any info on a cause and fix.
Old Jul 22, 2006 | 06:20 PM
LxMan1's Avatar
LxMan1
Sounds lit the OD button wiring in the shifter is damaged and going to ground. The one in our 2000 F250SD at work blows the fuse everytime that you push the button. No gauges, ETC. Yours must be bare on the hot side of the switch, ours is on the load side.
Old Jul 24, 2006 | 07:10 AM
BTAAA's Avatar
BTAAA
not sure if related
Don't think dash lights are on same circuit as cruise in my F-150. Just for the hell of it pull the cruise fuse and see if prog goes away.
Old Jul 24, 2006 | 08:22 AM
projectSHO89
Don't bother. The cruise is not on the same circuit.
Assuming it's F29 in the under-dash panel that is blowing, follow Jimmy's specific suggestion as it is the most likely cause.
Steve
Old Dec 13, 2006 | 07:18 PM
IofOsiris's Avatar
IofOsiris
Thumbs up constantly blown fuse #29 problem fixed!!!
LxMan1 you were right, I took the steering column cover off and the wire that leads out of the shifter had worn and was grounding out. I wrapped it thoroughly with electrical tape and the fuse hasn't blown since. Thanks!!!
Old Dec 14, 2006 | 03:59 AM
LxMan1's Avatar
LxMan1
Glad you got it fixed
Old Dec 14, 2006 | 06:03 AM
HomerWinzlow's Avatar
HomerWinzlow
Poor dealer tech was going to take the blame for it too... Happens all the time..
Pipeliner_86
Dec 3, 2015 07:01 AM
fireman-175
Nov 5, 2009 04:42 PM
colemanw
24
Jan 15, 2009 12:24 PM
Darth Baiter
Oct 16, 2005 10:45 AM
maticuno
1983 - 2012 Ranger & B-Series
Dec 4, 2003 11:13 PM
