Fire Hazzard Recalls
Old Jan 14, 2009 | 12:40 AM
colemanw's Avatar
colemanw
I have a 92 F-250 and am curious about the recall hubub. I did a search and people are talking about both a cruise control problem with leaking brake fluid igniting and an ignition switch problem.
Under the recall notices my 92 is not listed... what gives?
What should I be worried about? I want to be prepared if I have to take it to the dealer.
Thanks in advance
Old Jan 14, 2009 | 12:54 AM
colemanw's Avatar
colemanw
See?!?! My one odd ball year does not apply... Am I getting the shaft? Why would the 92 have different components?
General Article Detail Page - Ford
Trucks:
1997-2002 Expedition
1998-2002 Navigator
2002-2003 Blackwood
1993-1996 Bronco
2000-2003 Excursion (built prior to 11/4/02)
1992-2003 Econoline E-150/250/350
1996-2003 Econoline E450
2002-2003 Econoline E550
1998-2002 Ranger
1998-2001 Explorer/Mountaineer
2001-2002 Explorer Sport (2 door) & Sport Trac
2003-2004 F-150 Lightning
1993-2003 F-Series (Under 8500 lb. GVW)
1993-2003 F-Series (over 8500 lb. GVW) – all plants except Cuautitlan
1994-2003 F-Series (over 8500 lb. GVW) – Cuautitlan built only prior to 1/7/03
1995-2002 F-53 Motorhome
Cars:
1992-1998 Town Car
1992-1998 Crown Victoria
1992-1998 Grand Marquis
1993-1998 Mark VIII
1993-1995 Taurus SHO (automatic transmission)
1994 Capri
*equipped with speed control. Diesel engine equipped vehicles are excluded from recall
Old Jan 14, 2009 | 04:46 AM
EPNCSU2006's Avatar
EPNCSU2006
The 92 does not have the brake pressure switch on the master cylinder, so the cruise control recall does not apply. I'm not sure about the ignition switch recall, though.
Old Jan 14, 2009 | 06:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
yup. 92 does not have the cruise switch, and by 92 they solved the bad ignition switch problem by using a heavier contact switch.
Old Jan 14, 2009 | 08:53 AM
colemanw's Avatar
colemanw
good news! thanks guys
Old Jan 14, 2009 | 10:52 AM
Milwaukee1979F150's Avatar
Milwaukee1979F150
You have same one like this pic? If not then check dealer to see if it been fix.
Old Jan 14, 2009 | 12:36 PM
dan1101's Avatar
dan1101
I wish Ford would just give me the part, I don't think I'll ever get around to getting my truck to a dealer. I do all my own work, it never sees a garage.
I've already disconnected the electrical connection from the part in question, I don't miss cruise control.
Old Jan 14, 2009 | 01:39 PM
86F150302's Avatar
86F150302
I need to get the recall done on my Lightning . Thanks for the reminder!
Old Jan 14, 2009 | 01:49 PM
justin_brandstein's Avatar
justin_brandstein
Huh so my 95 is included that must be why it was unplugged
Old Jan 14, 2009 | 06:12 PM
fordman1090's Avatar
fordman1090
That picture is not correct. The plug on the MC is for low fluid level. The Switch in the recall is on the drivers side frame rail by the RABS unit. It looks just like an electric oil pressure sensor screwed on to a t fitting in the brake line.
All they do at the dealer is plug in a special adapter to the existing sensor.
It took them all of 5 minutes on my truck.
Good Luck
Old Jan 14, 2009 | 06:25 PM
fordman1090
Heres a picture of the sensor that is under recall.
Old Jan 14, 2009 | 08:18 PM
tjc transport
i ain't rite
actually, the picture was correct for the comment. what he said was that if your master looked like the picture, you did not have to worry about the recall.
Old Jan 14, 2009 | 09:17 PM
fordman1090
You can have that exact MC and have still have the recall. Thats the MC that my 93 has and i had the recall. The master has no relation to whether or not you need the recall.
I would contact ford and have them run the VIN if you are unsure if you need the recall.
And as far as i know the cruise system and the recall have nothing to do with the master. And the wires running from the master are for low fluid level like i said before, and they have nothing to do with either system.
Im not meaning to be rude by any means, i just want to make sure the guy gets help
Milwaukee and transport i dont want to offend yall, i just went in loops with ford about getting the recall on my truck and in the process learned some stuff.
I hope yall dont take this personally.
Old Jan 14, 2009 | 09:30 PM
colemanw's Avatar
colemanw
justin, can you show a photo of your master cylinder?
Old Jan 14, 2009 | 09:33 PM
colemanw's Avatar
colemanw
i did give my vin to the ford website and it listed nothing for my truck... i had been wondering if the company was trying to cheap out at the expense of fringe model years.
