Damn it !
Old May 25, 2006 | 07:14 PM
Mil1ion's Avatar
Mil1ion
gw is correct, I have never heard of chips wearing out from over use. Heat is the general cause of failures.
He said it probably over-heated ...fatigued , then and then failed probably from over use (ie:Having the computer running all the from being on FTE too much )
Eric, Why would I have them install thse parts instead of myself.
Do you think this is too much for me ?
I dont think it's out of my league.
About the gigabyte board, I talked to guy in Red Deer today who suggests one.
I'll look into it.
Thanks
Old May 25, 2006 | 08:05 PM
surewhynot's Avatar
surewhynot
Everything looks good Dennis. I have had good luck with MSI mobo's in the past. I'm currently using a Soltek mobo which is also a good choice. One thing you might want to think about is your power supply. Is it a quality brand? I have seen a lot of failures like you're describing being caused by voltage spikes from a faulty power supply. Just a thought. My real theory is it blew because you hit your 35,000th post a little too early!
Old May 25, 2006 | 10:09 PM
Mil1ion's Avatar
Mil1ion
SWN, I bought this PS in about February.
http://www.memoryexpress.com/index.p...ctID=5820&SID=
Couple of changes.
First the Case, I'm getting a black one instead of silver. (unless I chnage my mind tomorrow)
The MB ...? I am going with this one now.
http://www.memoryexpress.com/index.p...ctID=6524&SID=
But get this
I just tried booting up the other puter that fatigued and now it won't boot up at all.
At least before they ran the diagnostics on Tuesday and Wednesday the puter would boot up and run on 512MB of Ram.
Now Nothing.....Kaput !
Lights on ..nobody home
Could they have screwed it up more ?
Old May 25, 2006 | 11:41 PM
Greywolf's Avatar
Greywolf
Umm - Denny, this might sound totally stupid, but try replacing your power supply and see if it comes back up...
I've blown at least five of them over the years, and a quality PS makes a world of difference.
One of them I know for sure had at least two main V lines just plain quit on it. I swapped it out with better than it ever had and used that PC in Virginia almost until I left.
The cause of at least one of them was a cheap 3.5 inch floppy that fried internally and it took out everything using the same voltage.
Old May 25, 2006 | 11:44 PM
Mil1ion's Avatar
Mil1ion
You mean even if all the drives light up with power as they go through their motions ,the fans wail away,,,the power supply could be pooched ?
Old May 25, 2006 | 11:50 PM
Greywolf's Avatar
Greywolf
You know what?
If it was me, I'd open the case and take a look at what is connected and what isn't.
They probably left some things hanging inside.
But the next move would be to unplug everything from the PS and check the voltages on all the plugs with a meter. Some will be five volts, some twelve.
I've had 240 watt PS's that had some lines (connectors) good, while others were bad.
Hey, we're stupid right? We're consumers - and we all know some of us use DVD units as convenient slide-out coffee cup holders... We AIN'T supposed to know how a multi meter works, or be able to spot stuff that is unplugged!
I'm a geek, I admit it! But I can also slam a one ton dually axle up in under a diesel truck that was never designed to have it...
Old May 26, 2006 | 08:56 AM
Mil1ion's Avatar
Mil1ion
You're right.
I was under the impression I paid someone else to check the P/S (but did they ?)
Multi-meter out she comes....
I'm going to Calgary today to bring Michelle home for the weekend ad will be stopping by to pick up the new PC.
If this broken one gets fixed Michelle can use it instead of the other Aged one she;'s been playing Solitaire on ?
Me,well I'm moving on to new technology .....that will be obsolete in 8 months
Old May 26, 2006 | 10:06 AM
bryyce62's Avatar
bryyce62
It could also be your hard drive. If it doesn't boot up properly, try an alternate mode of startup.
gw
ford2go
Jun 6, 2012 07:20 AM
ford2go
18
Aug 1, 2007 05:00 AM
Mil1ion
22
Jan 3, 2006 11:19 PM
mbnv992
Sep 22, 2003 11:48 PM
