Front hub gets hot
Old May 21, 2006 | 07:50 PM
coldnorthpole's Avatar
coldnorthpole
Front hub gets hot
Hey guys,
I have a 93 F150 I6 and the right front hub started getting hot.
If I drive the truck for about 15 minutes and then park it, put my hand on the hub I can feel its hot. Not hot enough to burn me but hot enough to think there is a problem. Any ideas as to what might be the problem or is that normal? It doesnt do it on the left side.
Also, when I turn the steering wheel all the way to the left or right and back up it makes a clicking sound in the front end.....
Old May 21, 2006 | 08:03 PM
NavyMIDN08's Avatar
NavyMIDN08
the clicking sound would lead me to believe you probably have a bad u-joint in the front axleshaft. i had the same problem. odds are, thats whats is causing the heat as well. you probably have a blown u-joint that has the axleshaft locked out of line, and its spinning at an angle, causing the excess friction in the hub and the clicking when you have the wheel over. sounds like its time to tear that hub apart and check it out. typically its an easy fix. just keep everything clean, you may need to replace the bearings if overly worn from the axleshaft, and make sure you haven't shaved the aluminum lockout portion, as the shavings will wreck havok on every bearing on that side of the truck if you don't replace and clean everything.
good luck, its not that bad...
srercrcr's Avatar
srercrcr
Repack both the inner and outer hot bearing.....and hope it will be OK.
If not you could always get replacements.
Now if the spindle is all mucked up, your faced with filing down and living with it....or replacing the spindle....$$$.
Lesson: Preventive maintenance includes repacking bearings every 30,000 to 50,000 depending on your tolerance for risk.
Old May 21, 2006 | 08:28 PM
coldnorthpole
Unfortunately, the truck was owned by my father in law from day one.
He did take good care of the motor, but the other items on the truck may have suffered a bit. Now I get to do all the work.
Old May 21, 2006 | 09:29 PM
NavyMIDN08's Avatar
NavyMIDN08
join the club, i got my truck from my dad, my bronco from my his dad. that was the only problem with the bronco when i got it, bad u-joint... or maybe it was the slip-joint... either way it got replaced and now she runs smooth and is safe in the winter.
Old May 22, 2006 | 12:11 PM
andym's Avatar
andym
Unless you are driving around with your hubs locked, I seriously doubt it's a u-joint. Even then, I doubt it.
More likely it's either a sticky brake caliper (been there, done that) or you need your bearings re-packed.
Old May 22, 2006 | 01:37 PM
coldnorthpole
I believe it may be the sticky break caliper.
Reason I believe this is today I could hear the caliper on that side make a slight noise when I let off the break......
Man, this is getting more and more fun.
Old May 22, 2006 | 03:54 PM
srercrcr's Avatar
srercrcr
Well, the caliper assy is a moving part, so a slight noise doesn't sound unusual.
My moneys on bearings.
Old May 22, 2006 | 08:33 PM
havi's Avatar
havi
I'll have the Roast Duck
and in 1993, automatic hubs tend to fail. But my bet is either bearings, or the brakes are metal-to-metal.
Old May 22, 2006 | 09:09 PM
NavyMIDN08's Avatar
NavyMIDN08
either way, start on the outside, work your way in, the calipers are the easiest to diagnose, check them, if it persists, check the hubs
Old May 24, 2006 | 12:29 PM
coldnorthpole
Well fellas.
Pulled the tire of and did some surgery.
The bearings were shot. The wheel even had a little play in it.
Replaced the bearings, oil seal and its good to go now.
Even put some brand new Warn locking hubs on there so that should last me a while huh?
Old May 24, 2006 | 04:57 PM
srercrcr's Avatar
srercrcr
Now repack the other side, so you'll remember the front bearings were done at XXXX miles.
I said bearings. Who do I collect from?
Big_Al59
May 26, 2017 06:28 PM
WolfCreek540
Apr 10, 2017 12:56 AM
RRRAVEN
Dec 7, 2016 10:01 PM
billionj
Nov 21, 2015 09:53 PM
lestro
1997 - 2003 F150
Jul 28, 2015 11:32 AM
