Rotors- how warm ?
Old May 26, 2017 | 02:05 AM
Big_Al59's Avatar
Big_Al59
Rotors- how warm ?
Long story short, I had a tire chain break & tear up brake pads & rotor on the front of my 93 f250. Went ahead & replace bearings, rotor, caliper & pads while I was at it. This was passenger side, only did pads on drivers side. I had replaced caliper & rotor last year. Anyway after test driving it for about 5 miles at 45mph I returned home and felt the hubs & rotors. Hubs were cool but rotors were fairly hot, almost too hot to touch on both sides. Did a couple test stops, pedal felt right. Wheels turn ok, just a tad of resistance. Never checked my rotors after driving, is that normal they get pretty warm with hardly any braking?
Old May 26, 2017 | 08:42 AM
one_bolt_short's Avatar
one_bolt_short
Yes, especially with new pads.
[The pads are always in contact with the rotors, even when you aren't braking. That light friction causes heat. It's why your rotor faces have a heat sink between them and your wheel rims have holes in them to disperse the heat.]
Old May 26, 2017 | 09:47 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by one_bolt_short
.... It's why your rotor faces have a heat sink between them and your wheel rims have holes in them to disperse the heat.]
First I've ever heard of that. How do you explain solid brake rotors and steel wheels without holes?
Old May 26, 2017 | 12:22 PM
Big_Al59's Avatar
Big_Al59
I checked my son's truck, same year but a 350 this morning. His rotors got pretty hot (uncomfortable to touch) after a 15 minute drive, his were done by a local mechanic last fall.
Old May 26, 2017 | 12:44 PM
one_bolt_short
I dunno....
https://motofaction.org/mechanical-101/what-is-the-difference-between-a-vented-and-solid-brake-disc-or-rotor/
Tech Article: Brake Cooling Singular Motorsports
More surface area (fins in rotor) = greater heat dispersal. That's just physics.
I heard long ago, like in the late '70s and '80s, when people used Cragar solid aluminum rims they had brake fade issues. Fine on Friday Night cruisers and dragsters with a parachute or three strapped on their butt. Problematic on daily drivers.
I'm cool with it though. Trust but verify. But just cuz you haven't heard of it, doesn't mean it isn't so.
GoinBoarding's Avatar
GoinBoarding
I had a dragging drum (I adjusted it a touch too tight). Used an IR gun to check temperatures after a drive with minimal braking. If I recall correctly, the "normal" temps were in the neighborhood of 150F. That's a bit hot to touch for long, so it sounds like your truck is about the same. I'd consider it normal. I get around 60k miles to a set of pads.
Old May 26, 2017 | 12:54 PM
one_bolt_short
Lol. Oh Lord. Everyone is gonna go out and feel their rotors now....
Old May 26, 2017 | 01:00 PM
GoinBoarding
What makes you think that?
Old May 26, 2017 | 01:30 PM
Lead Head's Avatar
Lead Head
Brakes function by converting all of your vehicles kinetic energy (forward motion) into thermal energy (heat).
Your brake rotors will always be hot after a drive, especially a spirited drive where you're testing out your new brakes. The rotors have fins between the two surfaces to help dissipate heat. Wheels with holes aid this process. Solid rotors are generally only used in low speed, lightweight or rear-wheel applications where the braking load is low.
Old May 26, 2017 | 01:32 PM
one_bolt_short
This, but then I saw it was the OP doing an analytic diagnostic check. My apologies.
Big_Al59's Avatar
Big_Al59
Drums I could see getting them too tight but there's no way to really adjust pad tightness that I know of?
Old May 26, 2017 | 06:28 PM
GoinBoarding
Right, they are self adjusting. I mentioned it because the incorrectly adjusted drum was the reason I was shooting my brakes (discs included) with the IR temp sensor.
And yes, the brakes need to dissipate a lot of energy as heat. Solid rotors are likely a cost saver used in certain applications only where performance isn't a primary objective.
MiamiPSD
Jun 13, 2011 09:57 PM
hdman6
Apr 15, 2011 01:49 PM
renoduckman
Apr 27, 2009 12:31 PM
wanderinginNY
Mar 16, 2009 05:19 AM
powerstrokin007
Jan 31, 2008 06:17 PM
